BLRadar 2.0.138 and above
This is a sticky topic.
  • #16
    Rotech
    If you do the same thing as in post #7 this should fix it for you
    Cheers,
    Bob
    • #17
      Originally posted by Blade View Post
      Rotech
      I did what you said, devices came back. Question, Iam still in 138? Or is this a patch?
      Hector
      Win.2003 OS, HS3
      MyTrigger,ACRF2,W800,Zwave
      AP800,Honeywell Stat
      • #18
        .138 is fine. It should have converted the ini to an xml again
        Do you see all of your devices now?
        Cheers,
        Bob
        • #19
          Yes,all is normal. Thank you.
          Hector
          Win.2003 OS, HS3
          • #20
            I have put a fix in .139 for this
            It is in the beta section
            Cheers,
            Bob
            • #21
              Originally posted by Rotech View Post
              How did you go back to 137?
              I back up HS3 every night. I pulled in my nightly back up of the hspi.blradar from the day before I installed .138.
              Dale
              • #22
                Blade, I noticed today that BLRadar was not working. Checked the forum and found this thread. Some version did the ini conversion but my xml file was empty. So I renamed the .ini file back and deleted the 0 length xml file, restarted BlRadar. It correctly created a Xml file but there is no config link on my plugin page anymore (I tried rebooting incase HS was acting weird) . So right now I have a running config (I saw a zone turn on), BLRadar says its status is ok (and it is licensed), but no config link to jump to the configuration and if I try to go to /blradar manually I get a 404. So something about the config link registering is failing. I do see a log entry indicating an exception, but all it says is "This exception was caught during initialization: Object reference not set to an instance of an object" but doesn't give more info. So I am assuming the exception is occurring before the config page is setup. Is there a way to turn on more login manually to give you a way to track this down?
                Also, just FYI while Block does set the config link flag so that you can click on its name in the Installed plugins list and go to the default config page, BLRing and BLRoombaWifi do not.
                Best,
                Bill
