Is there a method, whether by script or event, to reset the status of an active zone to off prior to the motion sensor wait time?
For example, when a user leaves the zone and single taps the primary switch, this turns off the lights in that room and resets various virtual devices to default values (default dimmer values, whether motion control is enabled, etc). I would like this to also reset the active zone status, else if a person re-enters that room, triggering motion sensors, because the active zone is already on, it will not trigger the string of events.
I currently am running most sensors either binary or with very short recovery times, and a longer active zone wait time. I can build a workaround using another virtual device and a short active zone recovery, but that kinda defeats the purpose of blradar.
