Fix Device String
  • Fix Device String
    I am evaluating BLRadar, and did not know about the advice to link to a Virtual device when setting up a montion sensor. Now that I've done so, my device string is set to "Not Set" and does not follow the actual status. Is there a way to fix this for the devices?
    +1
    i have deleted the plugin. But my device string remain like what the op said
      It is likely because the plugin owns the device now
      I think I have something at home that will fix it - I will check once I am home and let you know
      Cheers,
      Bob
        Thanks for checking... By the way, I did Delete the BLRadar item, and then recreate with a virtual device. The status graphics work as expected, its just the string that has an issue...
          In control panel run the following: &hs.setDeviceString "2079", "", True
          Replace 2079 with your device reference.
          Larry
            Thanks lpcalcaterra
            That worked great! Was able to get mine fixed
