My use case is as follows:
Running:
The problems I am having is I cant get the device/sensor to work in BLRadar.
Before adding to BLRadar this device works, and is what I want to use as the trigger
But when I add that device as sensor to BLRadar the device stops changing status. I turned the relay on so I can hear it click, and while the relay is clicking and the load control is working, the "Home Security" device does not update once it is added to BLRadar.
Note in pic above that the switch binary is ON which proves the sensor detected motion, but the Security device stops updating status once under BLRadar control. None of the other devices created show up in the BLRadar dropdown box for me to add, the "Q111 Home Security" is the only one that is allowed to be added.
The sensor is configured like this in BLRadar:
I see this after ZWave inclusion
My parameters are set as follows:
(note, I turned Load Control to 255 for testing as I can then hear the relay click when motion is detected by the sensor, ultimately I want to turn that relay off by setting the Load Control to 0)
- Trying emulate the old X10 Hawkeye functionality.
- Turned the relay completely off.
- Would like to have motion "off" signal sent after 2 minutes of inactivity, BUT any motion within that 2 minutes should reset the timer. (standard BLRadar functionality)
- Need to integrate with BLRadar plugin.
Running:
- HS3 Pro Edition 3.0.0.478 (Windows)
- Zwave plugin v3.0.1.243
- BLRadar plugin v2.0.140.0
- Plug-Ins Enabled: BLBackup:,Z-Wave:,BLEditor:,BLRadar:,BLRF:,BLShutdown:,BLStat:,X10:,weat herXML:
