Change ON and OFF Values
  • Change ON and OFF Values
    Hey Blade, I'm testing out your plugin to replace Jim's as a) I like the price and b) I was having far too many issues with his w/o response.
    The one thing that I appear to be missing is the ability to change the ON and OFF values for a given device. Your plugin incorrectly determines my HSM100's light sensors to always being dark and I can't add some of my other non-standard on/off valued devices without this (I use a multitude of RS232 devices for occupancy detection. Some of which are play/stop devices, other having levels). With DooMotion I could use ON Value<100 OR >500 and the like.
    Is this a feature that your plugin is missing or am I just overlooking something?
    Cheers!
    I think this should be in BLRadar, not in BLAlarm but ...
    Each motion device has a device value of 0 for Off and 100 for On.
    As for the HSM100's, I can't help you with them. All Insteon here.
    Bryan
    Software/Hardware: Win10 Pro, HS 3 Pro, HS Touch, Echo, Edgeport/4, Z-Net w/88 Devices, Insteon PLM w/19 Devices, Nest, GC-100-6, W800RF32A, WS-2080 Weather Station (KMADRACU10)
    Plug-in/Scripts: Alexa API, BLBackup, BLGData, BLLED, BLLock, BLRF, BLTVGuide, Blue Iris, BLUPS, Current Cost 3P, DirectTV, FitbitSeer, Insteon, Nest, Pushover 3P, Random, Restart, Tasker, UltraGCIR3, UltraWeatherWU, Z-Wave
      The device values for devices should change by HS to 0 for Off and 100 for On.
      If you turn on debug logging in the plugin and capture one of the sensors reporting that is causing an issue and then open a help desk ticket on my web site (see my signature)
      Once the ticket is created you need to attach the debug log (BLRadar-Detailed.log located in your HS root folder).
      I will then have a look and see what is happening.
      Cheers,
      Bob
        Sorry, I didn't realize I posted in BLAlarm. I had meant BLRadar. Unfortunately none of my Homeseer HSM100 motion sensors work correctly as they set 255 for motion and 0 for no motion.
        I'll submit a help desk ticket
