I am in the process of converting from DM to BLRadar. I was successful in using the converter to import my devices into BLRadar, but i need some help with converting the Custom Action Codes that I have assigned to some of the devices.
I looked through the Help files, but I'm not very good at scripting - but I'm pretty good at cut and paste....
If someone could help me with the following, I think I can figure out the others from this example.
The current DM code is:
If DateDiff("n", Sensor.LastOn, Now) > Sensor.NormalElapsedTime Then
msg = "There is a guest at the front door"
hs.plugin("LEDAM").SendMessage "msg", "{5reg}{green}" & msg, "start", 12, 60, 5, 0
hs.speak CStr(msg), True
End If
If dm.NightTime Then hs.ExecX10ByName "Outside Front Entrance", "on"
dm.NewNoMotionDelayedEvent "Outside Front Entrance Off", "Outside Front Entrance:Off",10
The other issue that I need some help with the formatting of BL device text strings. While the text shows correctly in the HS device, when I try to use the text in my xLobby screens it displays as:
" Active Zone On  o days, 0 hrs, 3 mins, 9 secs)
How do I get rid of the extra characters? I just want to display "Active Zone On"..
THANKS!
End If
THANKS!
