Hey Blade, having almost fully transitioned from Doomotion I'm having one issue in that it doesn't appear that I can specify values for the Dusk/Dawn sensor(s).
I know that for motion I can use the RFXCOM option and set on/off but my motion sensors use a luminance value from 0-100 for light level. Can I somehow have BLRadar use value<3000 for Dusk and value>3001 for Dawn?
Failing that, can you suggest a way to have my lights turn on if a zone is currently occupied, lights off, but luminance less than a given amount?
I'm having issues where rooms are occupied from light to dark and the lights won't automatically turn on because the zone became active when the light level was still high. I tried creating an event that said basically: if zone occupied for at least X minutes and light has been off for at least X minutes and light level becomes X then turn light on. The problem with this is that if someone manually turns off the light switch when they're leaving a room then the light will pop back on once the above conditions are met.
Thanks!
Thanks!
