I just installed BLRadar and for some reason it changed one of my dimmers to an Active Zone with the active zone icon. I cant seem to change it back or even find it in the BLRadar settings. Can someone assist?
Confused...
Pete, sounds as though you didn't choose a virtual device to use with BLRadar and only supplied it the device code of the original node. This will cause the issue that you're seeing.
If you've deleted the node from BLRadar then you should be able to update/poll the switch from HS and it should return to normal.
You MAY have to use the "Control Panel" in hs and send a &hs.setdevicevalue and setdevicestatus to the correct values so that the icon changes back.
Originally posted by manxam View PostPete, sounds as though you didn't choose a virtual device to use with BLRadar and only supplied it the device code of the original node. This will cause the issue that you're seeing.
Originally posted by Blade View PostThere should be an uninstall in the bin folder for plugin
Once done then you will want to delete the BLRadar.mdb in the data\BLRadar folder and the hspi_BLRadar.ini file in the config folder
Then reinstall the plugin
Originally posted by Blade View PostAh yes... you will need to remove the devices and then shutdown HS and restart
Pete, that's weird. I made this mistake once with BLRadar and even with Doomotion but all of the times the Icon and status have reverted to the HS default once the node updates it status (either by poll or by status event generated by the event).
Either way, if this is a dimmer then make sure the switch is off so as not to confuse anything and try the following:
go to the control panel and type:
&hs.setdevicestatus("NODENUMBER",3)
&hs.setdevicevalue("NODENUMBER",0)
&hs.setdevicestring("NODENUMBER","")
and choose 'execute'
this SHOULD revert it all.
Originally posted by Blade View PostBLRadar creates 2 of its own devices. If those 2 are the ones you want to get rid of then just disable BLRadar and then delete the 2 devices from the HS stat web page.
Then make sure the hspi_BLRadar.ini and BLRadar.mdb files are deleted as well.
