I manually create a device with a code, say B1 and do not set any special options. This Test Device now has On and Off controls.
I then create a Motion Sensor in HS3 BLRadar for this new Test Device. Once I do that the status changes to the "No Echo (X Days, X Hours, X Min, X Sec)" Status..
The problem is this... Even when I trigger the device now with the On or Off Control as a test, the Status String and Icon of the Test Device does not change as it should through BLRadar.
I look in the Logs and it does show that when I use the On and Off controls the value does change for the Test Device, but it seems like BLRadar does not register this simple change. What am I missing here?
Marcus
Marcus
