I am trying to get MS10a motion sensors working in BlRadar as I moved houses and setup a new homeseer instance that used to use DooMotion. For these motion sensors it doesn't appear to change the motion status to on each time. It appears to not log an event every time motion is sensed. I need to act on an event each time motion is detected but something does not seem correct in trying to get these setup.
If I turn on debug logging for the motion sensor I can see in the logs that Homeseer is receiving the motion events from the sensor but BLRadar does not act the same as Doomotion did.
What I am trying to do is to setup a motion sensor to dim a light up to 100% whenever motion is detected and 5 minutes later if no motion is detected then dim it back down to 30%. Doomotion did this without any issues but i cannot get this to work in BLRadar for whatever reason
Has anyone successfully setup a MS10A motion sensor with BLRadar?
