...even with the plugin disabled.
Mar-06 7:13:21 AM Updater Install/Update of package BLRadar failed.
Mar-06 7:13:21 AM Updater Error Installation of package BLRadar failed. Try disabling the plugin first, then re-try the update.
Mar-06 7:13:21 AM Updater Error Copying source to C:\Program Files\HomeSeer HS3\HSPI_BLRadar.exe, detailed error: The process cannot access the file 'C:\Program Files\HomeSeer HS3\HSPI_BLRadar.exe' because it is being used by another process.
Mar-06 7:13:21 AM Updater Copying file: C:\Program Files\HomeSeer HS3\HSPI_BLRadar.exe
Mar-06 7:13:21 AM Updater Copying file: C:\Program Files\HomeSeer HS3\html\BLHelp\BLRadar\Images\maintainMovementPage.jpg
Mar-06 7:13:21 AM Updater Copying file: C:\Program Files\HomeSeer HS3\html\BLHelp\BLRadar\Images\addSensorPage.jpg
Mar-06 7:13:21 AM Updater Copying file: C:\Program Files\HomeSeer HS3\html\BLHelp\BLRadar\Images\optionsPage.jpg
Mar-06 7:13:21 AM Updater Copying file: C:\Program Files\HomeSeer HS3\html\BLHelp\BLRadar\Images\webInterface.jpg
Mar-06 7:13:21 AM Updater Copying file: C:\Program Files\HomeSeer HS3\html\BLHelp\BLRadar\BLRadar_Help.asp
Mar-06 7:13:21 AM Updater Copying file: C:\Program Files\HomeSeer HS3\html\Images\BLRadar\sound.gif
Mar-06 7:13:21 AM Updater Copying file: C:\Program Files\HomeSeer HS3\html\Images\BLRadar\noecho.gif
Mar-06 7:13:21 AM Updater Copying file: C:\Program Files\HomeSeer HS3\html\Images\BLRadar\maintain_motionsensor.gif
Mar-06 7:13:21 AM Updater Copying file: C:\Program Files\HomeSeer HS3\html\Images\BLRadar\maintain_duskdawnsensor.gif
Mar-06 7:13:21 AM Updater Copying file: C:\Program Files\HomeSeer HS3\html\Images\BLRadar\maintain_activezone.gif
Mar-06 7:13:21 AM Updater Copying file: C:\Program Files\HomeSeer HS3\html\Images\BLRadar\light.gif
Mar-06 7:13:21 AM Updater Copying file: C:\Program Files\HomeSeer HS3\html\Images\BLRadar\hspi_blradar.gif
Mar-06 7:13:21 AM Updater Copying file: C:\Program Files\HomeSeer HS3\html\Images\BLRadar\udmc.gif
Mar-06 7:13:21 AM Updater Copying file: C:\Program Files\HomeSeer HS3\html\Images\BLRadar\event.gif
Mar-06 7:13:21 AM Updater Copying file: C:\Program Files\HomeSeer HS3\html\Images\BLRadar\echo.gif
Mar-06 7:13:21 AM Updater Copying file: C:\Program Files\HomeSeer HS3\html\Images\BLRadar\dark.gif
Mar-06 7:13:21 AM Updater Copying file: C:\Program Files\HomeSeer HS3\html\Images\BLRadar\battery.gif
Mar-06 7:13:21 AM Updater Copying file: C:\Program Files\HomeSeer HS3\html\Images\BLRadar\activezoneon.gif
Mar-06 7:13:21 AM Updater Copying file: C:\Program Files\HomeSeer HS3\html\Images\BLRadar\activezoneoff.gif
Mar-06 7:13:21 AM Updater Installing package BLRadar
Mar-06 7:13:21 AM Updater Update HSPI_BLRadar.exe downloaded successfully
Mar-06 7:13:18 AM Updater Downloading update: BLRadar
Mar-06 7:13:18 AM Updater Starting download of updates
Mar-06 7:12:45 AM Info Plugin BLRadar with instance: has disconnected
Mar-06 7:12:45 AM Plug-In Shutting down Plug-In: BLRadar
