2.0.90.0
    2.0.90.0
    I'm confused (again!). When I tried to update to this release, there was a message about it requiring a later version of HS3. As far as I know I'm on the latest production release of HS3 (3.0.0.96).
    Does this version of BLRadar require a beta release of HS3, and if so, shouldn't it be listed under Beta Plug-ins and not show as an available update to a production version? In other words if this version is dependent on a beta release of HS3 then shouldn't it also be a beta release?
    Michael
    HS3, W10 Home, HSTouch, W800, Z-Stick+
    As I update any plugin I am requiring HS 3.0.0.130 because there was an issue with INI saving resolved in that build that caused many issues.
    If you do not want to update to 3.0.0.130 then do not update the plugin.
    I have been running 3.0.0.130 since it came out on my production machine and I have not had one issue with it.
    Cheers,
    Bob
      I update because that's the only way to find out what's changed/fixed. I wish there was another way, but that's the only way I've found. I keep hoping for a fix that will remove the requirement to disable the plugin, restart HS3, appy the updates, then restart BLRadar.
      Well then why hasn't 3.0.0.130 been released? Rhetorical, no need to answer.
      Michael
        Blade so anything that you release from now on (all plugins) requires ver .130 ?
        I am still on 196.
        Hector
        Win.2003 OS, HS3
        MyTrigger,ACRF2,W800,Zwave
        AP800,Honeywell Stat
          Yep any new builds will be changed to require .130
          Like I said I have been using it for weeks now with no issues at all.
          You can keep running the current version you are on until you overcome any fear of going to .130
          Cheers,
          Bob
            Can I use .143?
            Hector
            Win.2003 OS, HS3
              Yes
              Cheers,
              Bob
