New user needs help with BLRadar
    Hello
    I'm a brand new user of HS3 and I have the following installed
    HS3 - V3.0.0.181
    BLRF - V2.0.82.0 (using W800RF2)
    BLRadar - V2.0.104.0
    In BLRadar, I've managed to create motion and Active Zone devices and they are working ok.
    What I simply want to do is whenever an Active Zone is ON, turn on the lights and when it goes off, turn off the lights.
    In the Active Zone properties page there is an option to execute an event when this Active Zone goes on and another when it goes off.
    I can't get this to work.
    When the Active Zone goes on the entered event doesn't run, but when the active zone goes off, the entered event DOES run.
    What am I doing wrong??
    Turn on debug logging in the plugin.
    Capture the issue of the active zone on event not running.
    Turn off debug logging
    Attach the BLRadar-Detailed.log file zipped. It is located in HS3 root folder
    Cheers,
    Bob
      Thanks for the quick reply.
      I created the attached debug log as follows,
      Waited till all motion and zone devices were quiet (off)
      Turned on debug logging,
      Triggered one of the motion sensors
      Active zone turns on. (No event executes which it should)
      Waited for active zone to go off (Off event executes as it should)
      Turned off Debug logging.
      Hope this provides an answer as I really want to make this work.
      George
      (ghm)
        Did you set this "Motion Workshop Lights On" event on the motion sensor or the active zone?
        Cheers,
        Bob
          Both the ON event and the OFF event are set in the Active zone.
            Give me a full screenshot of the active zone and motion sensor
            Also, tell me the motion sensor code and the active zone code
            Cheers,
            Bob
              Here are the full screens you requested.
              There are two motion sensors (ms16a) in the zone. Both are configured identical.
                Here a screen shot of the device config in HS3
                Hope it helps
                  Try 2.0.105 in the HS3 updater
                  Cheers,
                  Bob
                    I installed v2.0.105.0
                    Ran a test. No luck
                    Just to see of it was a problem with my motion and zone devices, I deleted them in BLRadar, then deleted them in HS3 and recreated them.
                    Still no luck.
                    attached is another debug log I made during the test
                    Sorry for being a pest.
                    George
                      I do not see a debug log attached
                      Cheers,
                      Bob
                        Oops. attached wrong file.
                        here it is.
                          Try 2.0.106
                          Cheers,
                          Bob
                            SUCCESS !!!
                            Its now working as I expected.
                            On the Active Zone page, underneath the "Event Name to Execute" box,
                            There is an option "Number of minutes sensor must be off before re-trigger".
                            The minimum number I can enter here is 1. Why cant I have 0?
                            There are times when I may be working still and the lights go off due to no motion. As it is, I'll have to wait 1min before I can retrigger the motion sensors for the lights to go on.
                              I will take a look
                              Cheers,
                              Bob
