UDMC Script
  • UDMC Script
    Just added, hs.writelog("BLRadar","Motion On") in UDMC window.
    And it gives me below error.
    Compiling script BLRadar\BLRadar_On_test.vb: Declaration expected.
    Compiling script BLRadar\BLRadar_On_test.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
    Tasker Plugin / Speech Droid
    Tonlof | Sweden
    HS2 or HS3?
    Send me a screenshot of the screen
    Cheers,
    Bob
      Originally posted by Blade View Post
      HS2 or HS3?
      Hi Blade, it's HS3
      Tonlof | Sweden
        I do not see any issues with that
        This errors seems odd to me
        It is like your .net may be messed up
        Can you attach your settings.ini file zipped from your config folder
        Cheers,
        Bob
          Not sure what I have done but the errors is gone.
          Using the same simple writelog, when I press the testbutton it's execute the code. But it's never trigger by a real movement.
          Last Activity is updated each time the sensor change status and the devicestring as well.
          Tonlof | Sweden
            Here is the settings.ini
            Still no success with the code, Testbutton works fine with the code.
            Tonlof | Sweden
              So the code works... it is just not triggering on movement?
              Do you have UDMC code enabled on the options page
              Do you know for sure the motion is working
              Cheers,
              Bob
                "Enable User Defined Motion Code Scripting" is enabled in options tab.
                BLRadar change the device string each time motion / nomotion trigger.
                Not sure why one of the sensor change to 735791 days but I don't know if this has anything with the non working code to do or not.
                Tonlof | Sweden
