problems after restoring config in HS3
  • problems after restoring config in HS3
    I recently had to use a backup for my HS3 database and I ended up with no sensors in BLradar after restoring the data base, so I started to re-add the sensors but when it came to the virtual device I created for active zones they did not appear in the drop down to re add the active zones. The devices show up in the device list in HS3 it is almost like blradar thinks they are already there but they are not showing up how can I fix this
    Any help would be appreciated
    Thanks Ken
    HSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
