I have tried to update BLRadar a few times over the past few days and I keep getting this message.
WARNING: Failed getting InterfaceStatus from BLRadar - the interface was not found in the list of active interfaces, the list may need to be refreshed.
I did the disable and enable but no difference.
The log file:
Dec-21 10:20:50 PM Plug-In Finished initializing plug-in BLRadar
Dec-21 10:20:49 PM BLRadar start BLRadar plug-in has been initialized
Dec-21 10:20:48 PM BLRadar start User Defined Motion Code has been loaded
Dec-21 10:20:48 PM BLRadar start Sensors and Active Zones have been loaded.
Dec-21 10:20:46 PM BLRadar start Checking devices owned by BLRadar
Dec-21 10:20:46 PM BLRadar start Loaded configuration successfully
Dec-21 10:20:45 PM BLRadar start BLRadar version is: 2.0.110.0
Dec-21 10:20:45 PM BLRadar start Initializing BLRadar...
Dec-21 10:20:45 PM Info Plugin BLRadar has connected. IP:127.0.0.1:59342
Dec-21 10:20:45 PM Updater Re-initializing plugin after update.
Dec-21 10:20:45 PM Updater Install/Update of package BLRadar failed.
Dec-21 10:20:45 PM Updater Error Installation of package BLRadar failed. Try disabling the plugin first, then re-try the update.
Dec-21 10:20:45 PM Updater Error Copying source to C:\Program Files (x86)\HomeSeer HS3\HSPI_BLRadar.exe, detailed error: The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS3\HSPI_BLRadar.exe' because it is being used by another process.
Dec-21 10:20:45 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\HSPI_BLRadar.exe
Dec-21 10:20:45 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\BLHelp\BLRadar\Images\maintainMovementPage.jpg
Dec-21 10:20:45 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\BLHelp\BLRadar\Images\addSensorPage.jpg
Dec-21 10:20:45 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\BLHelp\BLRadar\Images\optionsPage.jpg
Dec-21 10:20:45 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\BLHelp\BLRadar\Images\webInterface.jpg
Dec-21 10:20:45 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\BLHelp\BLRadar\BLRadar_Help.asp
Dec-21 10:20:45 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\Images\BLRadar\sound.gif
Dec-21 10:20:45 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\Images\BLRadar\noecho.gif
Dec-21 10:20:45 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\Images\BLRadar\maintain_motionsensor.gif
Dec-21 10:20:45 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\Images\BLRadar\maintain_duskdawnsensor.gif
Dec-21 10:20:45 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\Images\BLRadar\maintain_activezone.gif
Dec-21 10:20:45 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\Images\BLRadar\light.gif
Dec-21 10:20:45 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\Images\BLRadar\hspi_blradar.gif
Dec-21 10:20:45 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\Images\BLRadar\udmc.gif
Dec-21 10:20:45 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\Images\BLRadar\event.gif
Dec-21 10:20:45 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\Images\BLRadar\echo.gif
Dec-21 10:20:45 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\Images\BLRadar\dark.gif
Dec-21 10:20:45 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\Images\BLRadar\battery.gif
Dec-21 10:20:45 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\Images\BLRadar\activezoneon.gif
Dec-21 10:20:45 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\Images\BLRadar\activezoneoff.gif
Dec-21 10:20:45 PM Updater Installing package BLRadar
Dec-21 10:20:45 PM Updater Update HSPI_BLRadar.exe downloaded successfully
Dec-21 10:20:42 PM Updater Downloading update: BLRadar
Dec-21 10:20:22 PM Info Plugin BLRadar with instance: has disconnected
Dec-21 10:20:22 PM Updater Plugin is loaded, unloading before updating.
Dec-21 10:20:22 PM Updater Starting download of updates
The log file:
