Active zone ON, but value = 0
  • Active zone ON, but value = 0
    It happens a lot that the active zone is ON, but the value = 0.
    How can that happen?
    Peter
    http://ohh.pcgsm.nl
    I just checked mine here and they are showing a value of 100. That is odd
    Cheers,
    Bob
      I think I found the problem.
      When the zone is activated, it will run the :
      blradar.PluginFunction("SuspendActiveZone", new Object(){"xxx"})
      command, to keep the zone active on no motion in that zone.
      The motion sensor in the nearby room will resume the zone with this command:
      blradar.PluginFunction("ResumeActiveZone", new Object(){"xxx"})
      When that command is executed, the zone string is still "active zone on", but the value changes to 0.
      I use the value to check if the zone is active in my scripts.
      How can this be solved?
      Peter
      http://ohh.pcgsm.nl
        It should still update the device string.
        Can you capture this happening with debug logging turned on.
        Then send me the debug log zipped
        Cheers,
        Bob
          This is the debug file.
          Peter
          http://ohh.pcgsm.nl
            I do not see any processing for active zone ref: 1206
            Is this the one you tested with?
            Cheers,
            Bob
              Active zone tested is 1210, badkamer bezet.
              But problem happens with every zone.
              Peter
              http://ohh.pcgsm.nl
                I noticed that 1210 does not have a device code assigned to it.
                Some of your other active zones do.
                All of my active zones have a device code
                Cheers,
                Bob
                  It has device code c66,
                  But I have zones without a device code.
                  Should they all have one?
                  Peter
                  http://ohh.pcgsm.nl
                    The device string looks correct in that image for 1210
                    Does the device code show in BLRadar for that device?
                    Cheers,
                    Bob
                      This is what I see:
                      Peter
                      http://ohh.pcgsm.nl
                        OK no device code in BLRadar
                        I wonder if you added it to BLRadar and then updated the device code in HS3
                        Cheers,
                        Bob
                          When I enter the zone, zone goes active and status = 100
                          When I go to the next room with a motion sensor that activates the zone again, then status changes to 0 while zone is still active.
                          Peter
                          http://ohh.pcgsm.nl
                            Attach your hspi_BLRadar.ini zipped
                            Cheers,
                            Bob
                              This is the ini file:
                              Peter
                              http://ohh.pcgsm.nl
