Active zone ON, but value = 0
  • #31
    1210 Badkamer bezet Active Zone Badkamer 1/17/2016 20:37:21 C66
    2419 Badkamer Motion Badkamer 1/17/2016 20:34:20 eth484_3_6
    1211 Gang boven bezet Active Zone Gang boven 1/17/2016 20:37:18 Z30
    2393 gang boven Motion Gang boven 1/17/2016 20:36:18 eth484_1_1
    Badkamer = bathroom
    gang boven= corridor
    Peter
    http://ohh.pcgsm.nl
    • #32
      This is puzzling
      I added more debug logging
      Can you try 2.0.116 in the updater and capture another log of the same thing
      Specify what you did in the log file
      Cheers,
      Bob
      • #33
        21:29 start log
        21:29:30 went from hobbykamer to corridor to bathroom
        21:30 went to corridor
        21:30:50 status zone bathroom went 0 (made a speak event to notice)
        22:30:45 went to bathroom
        22:31 went back to hobbykamer and stopped logging.
        Few minutes later zone bathroom went off.
        Peter
        http://ohh.pcgsm.nl
        • #34
          Do you have any scripting code set for 2419 or 1210 in the plugin?
          Cheers,
          Bob
          • #35
            2419:
            blradar.PluginFunction("ResumeActiveZone", new Object(){"1211"})
            1210:
            blradar.PluginFunction("SuspendActiveZone", new Object(){"1210"})
            Peter
            http://ohh.pcgsm.nl
            • #36
              OK That is odd then.
              In the debug log I do see 1210 value changing to 0 but I am stumped right now how it is happening. I see a callback from HS3 into BLRadar that the 1210 device changed from 100 to 0 but I am not sure what initiated it.
              Cheers,
              Bob
              • #37
                Hi Bob,
                Did a lot of testing, including making new Active zone devices, to see when things go wrong.
                The new active zone for the bathroom was working ok.
                Until I changed the house/unit code to C66. Then it went wrong again.
                I then remember that I had a script running for the 'old' doomotion zones from HS2. That was triggering the zones with the value = 0 commands!
                So problem is solved.
                I want to thank you for all your help to find my problem.
                But it was my fault, not the BLRadar plugin.
                Peter
                http://ohh.pcgsm.nl
                • #38
                  No problem.
                  I could see it changing to 0 but I could not find it happening in the plugin.
                  Glad you got it sorted out
                  Cheers,
                  Bob
