No problem.
I could see it changing to 0 but I could not find it happening in the plugin.
Glad you got it sorted out
Active zone ON, but value = 0
Hi Bob,
Did a lot of testing, including making new Active zone devices, to see when things go wrong.
The new active zone for the bathroom was working ok.
Until I changed the house/unit code to C66. Then it went wrong again.
I then remember that I had a script running for the 'old' doomotion zones from HS2. That was triggering the zones with the value = 0 commands!
So problem is solved.
I want to thank you for all your help to find my problem.
But it was my fault, not the BLRadar plugin.
OK That is odd then.
In the debug log I do see 1210 value changing to 0 but I am stumped right now how it is happening. I see a callback from HS3 into BLRadar that the 1210 device changed from 100 to 0 but I am not sure what initiated it.
2419:
blradar.PluginFunction("ResumeActiveZone", new Object(){"1211"})
1210:
blradar.PluginFunction("SuspendActiveZone", new Object(){"1210"})
21:29 start log
21:29:30 went from hobbykamer to corridor to bathroom
21:30 went to corridor
21:30:50 status zone bathroom went 0 (made a speak event to notice)
22:30:45 went to bathroom
22:31 went back to hobbykamer and stopped logging.
Few minutes later zone bathroom went off.Attached Files
This is puzzling
I added more debug logging
Can you try 2.0.116 in the updater and capture another log of the same thing
Specify what you did in the log file
1210 Badkamer bezet Active Zone Badkamer 1/17/2016 20:37:21 C66
2419 Badkamer Motion Badkamer 1/17/2016 20:34:20 eth484_3_6
1211 Gang boven bezet Active Zone Gang boven 1/17/2016 20:37:18 Z30
2393 gang boven Motion Gang boven 1/17/2016 20:36:18 eth484_1_1
Badkamer = bathroom
gang boven= corridor
installed 115.
debug on
Go in bathroom, motion
go to corridor, motion corridor
go to bathroom, motion bathroom
When I am still in the bathroom, status zone bathroom goes to 0, string stays on active zone ON.
leave the bathroom, few minutes later bathroom active zone goes to off, like it should.
So I think when I enter the batroom for the second time, SuspendActiveZone suspends the string, but not the status? status is even going to 0 while the bathroom motion sensor is activated multiple times. (my motion sensors detect motion, go on and within 1 second go off again, still motion? go on within 1 second go off again....,that is the way they work. It are not the motion sensors that can stay on for multiple minutes)
Attached the debug:Attached Files
OK is the bathroom sensor sending another ON when you go back in?
Try 2.0.115 in the HS3 updater and see if it helps.
But when I am back in the bathroom, status must not go to 0, while string say active zone ON.
When you leave the bathroom the corridor sensor resumes the active zone so that means the plugin will continue to process it.
When you go back in the bathroom does it suspend the active zone
When I go back to the bathroom, the status for the bathroom zone goes to 0 after a short time and the string stays on active.
When I am in the bathroom, active zone has to stay on and status has to stay 100, not 0.
Originally posted by peterpc View PostInstalled 114.
When I enter the bathroom , active zone goes ON and status is 100.
When I leave the bathroom, the motion sensor in the corridor will trigger and send the "blradar.PluginFunction("ResumeActiveZone", new Object(){"1210"})" command.
When I then leave the bathroom, after the right time the zone goes to OFF.(status was already OFF)
I have attched the log.
