Virtual devices
  • Virtual devices
    I want to use some ibeacons as sensors for presence. To make them part of the occupied sensor of the home I want them to be movement sensors.
    I made virtual devices for them and and de ibeacons device to blradar with the virtual device to update the status.
    After adding this device to blradar the original ibeacon device is status only! I can't run no more events to change the ibeacon status.
    What is the meaning of the virual device if the original is also changed?
    Peter
    (Off topic, but how do you integrate iBeacons with HomeSeer?)
      mqtt plugin and aprilbrother beacon reciever
      Hi I have a beacon receiver from april brother and the MQTT plugin.
      Some events en running.
