Database file location?
  • Database file location?
    I have a problem with BLRadar having none of my sensors in the plugin (probably the result of a power outage that lasted longer than my UPS). I want to restore from backup. What is the name and location of the BLRadar sensor database file?
    Elliott
    [HS3 root]\Data\BLRadar\BLRadar.s3db
    Cheers,
    Bob
      Thanks!
        Well, my diagnosis is incorrect. The database file is there. Why would the plugin state:
        "There are no sensors configured in the plug-in."
        When I go to individual rooms that have sensors, I see sensors that indicate "echo" or "no echo" and using the usual BLRadar images. Disabling and enabling the plugin a couple of times did not fix the problem.
        Elliott
        EDIT: Fixed problem by restoring file in Config folder: hspi_Blradar.ini
