I need to trigger several events when an active goes active. I don't want any delay before retrigger. I have created a active zone with the name "BLActive1". The active zone is configured with no "on" event and no "off" event. I have my "external" events set up with a trigger "BLActive1" set to on. BLActive1 is set to a virtual device with a device code of "r1". The device code shows in BLRadar as "r1". So can I trigger an event with the virtual device code for the active zone just like any other virtual device. Currently, none of my events trigger when the virtual device BLActive1 go to an "on" condition.
"external" event trigger
Originally posted by Blade View PostSo you are setting an active zone ON manually? Active zones are assigned to multiple motion sensors and will go ON when any motion sensor goes ON
Show me some screenshots of what you are doing
Attached are screen shots.
ThanksAttached Files
I had the same issue. I had to use Spud's EasyTrigger to check if the string changed. If it did I check if it's on or off. Attached is an image for my "On" event. You can see in the first block how I check for the string change.
Other things I did:
- I don't use the images in BLRadar. I leave them blank and use the Status Range Images instead.
- I matched the virtual device's status strings to match BLRadar. No real reason for this than I liked it this way.
- I removed the time off the status. My "fix" doesn't require that, but I didn't see a need for it.
@Blade, My guess is that the way you are setting the value for the active zone devices you are telling it not to trigger events. I think when you do CAPI it works like this, I'm not sure. All I know is that I can't trigger events off changes in those device's values.
Perhaps add an option for Active Zones to allow them to trigger events. My motion events depend on more than just motion sensors to trigger them so I can't use the on/off events in the BLRadar setup. I merely use BLRadar to group motion sensors to make event creation easier.
Originally posted by sirmeili View PostI had the same issue. I had to use Spud's EasyTrigger to check if the string changed. If it did I check if it's on or off. Attached is an image for my "On" event. You can see in the first block how I check for the string change.
Other things I did:
Should I put in a feature request for this on your site? I ran into this again after setting up some more motion sensors in BLRadar. Woke up to the kitchen lights still being on (My bad, I should have remembered that BLRadar devices didn't trigger events).
Originally posted by Blade View PostHave you tried using the "user defined motion code" or the "When this active zone goes ON" for the active zone?
And the "When this active zone goes on" does trigger an event, but limits me to 1 event which as far as I know doesn't have any other options/conditions.
In my case, I use the motion sensors, but I also have them tied to a virtual device that determines if want "automatic lights" to work. It seems to me that you are setting the value for these devices but specifically telling homeseer to not trigger events. I know the setDeviceVAlueByRef() and setDeviceValueEX() methods both allow you to send in "false" for the last parameter to accomplish this. What I am asking is if it's possible to send true instead (could be that you could be using another method to change the value that is not causing it to trigger events).
Basically, I'm only using BLRadar to group motion sensors into 1 device and triggering events off of that. It may be able to do a lot more, but right now that is my use case (And was enough for me to buy it )
Originally posted by Blade View PostTry 2.0.124 and let me know if it does what u need
Attached is a picture of the event. Also pictured is a picture of the log. You can see where the event based on device strings ran, but the the test event didn't .
Originally posted by Blade View PostIf you use 100 for ON and 0 for OFF it might trigger it
Or am I misunderstanding?
Originally posted by Blade View PostHmm I changed the call to trigger events - they should have triggered
I am doing remoted in to my PC from Florida
Let me check again
I'll restart everything just to be sure. Maybe because it's a "status only" device? I doubt that's it.
