Nighttime error?
  • Nighttime error?
    UDMC:
    If blradar.NightTime() Then
    blradar.PluginFunction("ControlDevice", new Object(){"2ND FLOOR Stairway Lighting", "dim", 15})
    blradar.PluginFunction("NewDelayedEventForNoEcho",New Object(){"Stain Light control","2ND FLOOR Stairway Lightingff",5,""})
    End if
    PHP Code:
    Oct-23 12:34:23 PM         Error    Compiling script BLRadar\BLRadar_On_test.vb'NightTime' is not a member of 'HomeSeerAPI.PluginAccess'.
    Oct-23 12:34:23 PM         Error    Compiling script BLRadar\BLRadar_On_test.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn'use any aliases
    Larry
    Try this:
    If blradar.PluginFunction("NightTime", Nothing) Then
    End if
    Cheers,
    Bob
      Thanks Bob.
      For HS2 use blradar...
      For HS3 use blradar.PluginFunction
      Larry
