Rest plugin action failed
  • Rest plugin action failed
    I seem to be getting a lot of these errors..
    Dec-25 13:23:09 ErrorEvent SYSTEM PIR Dining room Blradar reset plugin action failed:Object reference not set to an instance of an object.
    The pir in question is on an RFXCOM and plug-in, but it seems to do it to other z-wave ones too.
    Any idea how to fix this, and what is causing it? Is it a corrupt.db (again)?
    Assistance much appreciated.
    Cheers
    J
    Do not think those are coming from BLRadar
    Cheers,
    Bob
      I've also not been able to update higher than 2.0.116 version of the the plugin (which I'm still on) as none of the blradar devices update. Something isn't right, and needs sorting. Your help appreciated.
      I wondered about deleting the .db etc to see if it would help. What's the procedure? Without having to rebuild everything.
      Cheers
      J
        You will need to capture a debug log of the issue with the devices not updating
        Attach it zipped
        Cheers,
        Bob
