Crazy Setpoints causing family to melt...
  • #16
    Looks like there is an event running this one setting it to 63
    02/09/2018 06:02:47:399 PM : v2.0.70.0 - HandleAction() started
    02/09/2018 06:02:47:399 PM : v2.0.70.0 - HandleAction(): ActInfo.TANumber --> 1
    02/09/2018 06:02:47:399 PM : v2.0.70.0 - HandleAction(): ActInfo.SubTANumber --> 0
    02/09/2018 06:02:47:399 PM : v2.0.70.0 - HandleAction(): ActInfo.evRef --> 2916
    02/09/2018 06:02:47:399 PM : v2.0.70.0 - HandleAction(): ActInfo.UID --> 1678
    02/09/2018 06:02:47:399 PM : v2.0.70.0 - HandleAction(): strAction.Result --> True
    02/09/2018 06:02:47:399 PM : v2.0.70.0 - HandleAction() strAction.ActObj contains data
    02/09/2018 06:02:47:399 PM : v2.0.70.0 - HandleAction(): strAction.WhichAction --> ThermostatCommand
    02/09/2018 06:02:47:399 PM : v2.0.70.0 - HandleAction(): Act1.ToString -->
    ActionThermostatCommand:
    ActionUID: 1678
    Command: Set Heat Setpoint
    ThermostatNumber: 1
    Value: 63
    Schedule:
    Cheers,
    Bob
    • #17
      Looks like event ref: 2916
      Cheers,
      Bob
      • #18
        ActionUID: 1678
        ThermostatNumber: 1
        Value: 63
        Schedule:
        Yes, but instead go being set to 63, it was set to 71. And none of my set points are set for 71 degrees.
        I have included my schedule for your reference.
        • #19
          Can you paste in a screenshot of the event ref 2916
          Cheers,
          Bob
          • #20
            Bob,
            How do I determine the reference number of an event?
            • #21
              Bob,
              If this helps, here is the only place I see a temperature of 71 mentioned (Min and Max Heat Setpoint Options). Could this somehow be set when a schedule changes?
              • #22
                Originally posted by jpape View Post
                Bob,
                Do the following:
                1. Disable BLStat
                2. Edit the hspi_BLStat.ini file and change debugLevel=true
                3. Save INI file
                4. Re-enable BLStat
                Once BLStat has been started for a minute then turn off debug logging on the options page in BLStat
                Attach the BLStat-Detailed.log zipped here
                It is in the HS3 root folder
                Cheers,
                Bob
                • #23
                  Do the following:
                  1. Disable BLStat
                  3. Save INI file
                  4. Re-enable BLStat
                  Here you go.
                  • #24
                    Here is event 2916
                    EventRef: 2916
                    EventName: Set Away Mode
                    GroupId: 46182508
                    GroupName: Climate
                    Cheers,
                    Bob
                    • #25
                      Here is event 2916
                      EventRef: 2916
                      GroupId: 46182508
                      GroupName: Climate
                      Here is the event Bob.
                      • #26
                        You are setting the heat setpoint twice in that event.
                        That explains where the 63 and 85 are coming from
                        Cheers,
                        Bob
                        • #27
                          And with the BLStat maximum heat setpoint at 71, when it is set to 85 the plug-in overrides it and sets it to 71. By the event it is set to 63, then 85, then the plug-in sets it back back to 71 all at once. It also looks like the event might be double triggering:
                          2/8/2018 6:08:37 PM Action Den Thermostat (1) Heat Setpoint set to 71
                          2/8/2018 6:08:37 PM Action Den Thermostat (1) Heat Setpoint set to 85
                          2/8/2018 6:08:37 PM Action Den Thermostat (1) Heat Setpoint set to 63
                          Setting Cannot Re-Run for 5s would stop the double trigger.
                          Randy Prade
                          Aurora, CO
                          Prades.net
                          • #28
                            Yes it does look like it is running the event twice
                            The plugin will set it back to your max which is 71
                            Cheers,
                            Bob
                            • #29
                              Nice catch.
                              I have changed my event and will see how it goes. I appreciate the time spent on this issue and catching my mistake.
                              I really need to wear my glasses more :-0
                              Judd
