Yesterday all my schedules and settings for my thermostats disappeared. I backup my HS3 regularly; can I copy over a certain directory and have everything restored? Thanks for the help.
Lost Schedules/Settings
I have quite a number of schedules that have remained for a couple of years without issue. They are in the .ini file. I have events that will load different schedules based on work schedule, outside temperature, holidays and occupancy. They all load reliably.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Originally posted by jpape View PostBob,
It looks like the schedule is not being saved to the ini file. You can look at the screen captures below.
I have included the ini file and the one schedule i have.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
That is very odd
The log says the object and INI was updated
02/14/2018 10:04:03:200 PM : v2.0.71.0 - PagePut: new schedule class has been built
02/14/2018 10:04:03:200 PM : v2.0.71.0 - PagePut: schedule added to dictionary and INI
Can you edit it once you add it in the plugin?
If it is not in the INI file then it will not load when you restart but does it load up again right after you add it in the plugin. That would tell me that the class is created within the plugin but for some reason it will not write the INI file
Could your INI file be read-only?
Yes i can edit the schedules once created. But if i restart the plugin or Homeseer the schedules disappear.
The ini file is not read only. If i change a setting in the Options screen it does get reflected in the ini file.
Another thing i have wondered about, should there be a field next to the "Set" button for each stat?
I am running Windows 10 if that means anything.
Judd
