Plugin action failed:Object reference not set to an instance of an object
    My Trane XL624 was detected nicely and seems to know what's on the display. However when I try to execute the BLStat thermostat command to load a different schedule it does not load it, rather it throw the above noted error in the log. I've re-initialized however that did not change anything.
    Suggestions?
    Interestingly it is able to load a schedule in another event here
      I was able to resolve the issue by randomly reordering the actions in the event. Then this additional tidbit appeared in the logs:
      Away, Action of BLStat: Thermostat Command could not be carried out because its configuration is not complete.
      So then I selected a different schedule, then reselected Away and it now works.
      Not clear if the root cause was this action running directly after a "Run Event" or if the Away schedule (which is the first in the DD) was not actually selected.
      Hopefully this helps someone....
