where do I get the filter change scripts
  • where do I get the filter change scripts
    I own the BLSTAT plugin (HS3pro) I have a filter change device which does not display my most current date. It appears I need a filter change script to reset the date. Is there a place I should be able to find this.
    Bill
    You can reset it manually at the bottom of the Thermostats page in BLStat configuration. You can use immediate scripts to set the virtual devices or use the plug-in function described in the help
    Click image for larger version  Name:	E364B787-A08A-4034-8C24-465E390B59C1.jpeg Views:	0 Size:	26.7 KB ID:	1343301
    Randy Prade
    Aurora, CO
    Prades.net
