ok. so I want the system to operate off the schedule, (which it does fine) and I want to be able to set a higher temp and the system keep it for 30 minutes then revert back to the schedule. it seems to have issues with that... sometimes it does, and sometimes it doesn't.
I have the "Manual setpoint changes" enabled in the thermostat options.
and I have the Allow manual setpoint changes for "30" minutes before resuming the thermostat schedule.
I did not set a maximum change allowed.
now I have changed the temperature at the thermostat, via HSTOUCH, from the device management panel, and from Alexa voice commands.
(basically whatever is in front of me at the moment)
I have yet to identify which times it does and does not work.... but I know the last time I did it from Alexa a couple hours ago and it never reverted back.
Has anyone else seen this issue?
