Z-Wave Thermostat Manufacturer Information Needed
This is a sticky topic.
  • Z-Wave Thermostat Manufacturer Information Needed
    OK here is the deal.
    I need some help in determining the values for the following information:
    Manufacturer ID
    Manufacturer Product ID
    Manufacturer Product Type
    These exist in HomeSeer but they are only numbers and Rich cannot give me the table of what the manufacturers are because it is bound by the Z-Wave SDK license. I fully understand this but I need the information so this is why I need your help.
    I am attaching a VB.Net script that will get this information for all thermostats assigned in HomeSeer. What I need from you is for anyone running BLStat I need you to do the following:
    1. Unzip the script into your HS scripts folder
    2. Go to the Control web page (/ctrl) and in the "Immediate Script Command" box type the following and click "Execute Command"
    &hs.RunEx "Display_ZWave_Thermostat_Device_Info.vb", "Main", ""
    This will generate a report called Display_ZWave_Thermostat_Device_Info.log in your HS root folder. It should list a section for all Z-Wave thermostats that you have.
    I then need you to reply back to this thread with the following information for each Z-Wave thermostat that you have:
    Thermostat Make and Model (eg: Trane TZEMT400AB32MAA)
    Z-Wave Manufacturer ID - this will be in the log
    Z-Wave Product ID - this will be in the log
    Z-Wave Product Type - this will be in the log
    This will help me figure out what model of thermostat you are running with the plug-in.
    You only need to do this if your thermostat information is not already listed by another user
    I appreciate your help
    Let me know if you have any issues.
    Cheers,
    Bob
    Thermostat Make and Model TZEMT400AB32MAA
    Z-Wave Manufacturer ID - 139
    Z-Wave Product ID - 21553
    Z-Wave Product Type - 21586
    I have two of these and they both are the same.
    I also have this:
    Originally posted by From the Log
    Misc: 4656
    Supports Pre-Set Dim: 0
    Supports Extended Dim: 0
    SmartLinc Switch: 0
    No Logging Changes: 0
    Status Only: 16
    Is Thermostat: 0
    Include in PowerFail: 0
    Value names are selectable from the Control screen : 0
    Create voice command(s): 512
    Voice commands must be confirmed for this device: 0
    uses the Compose preset-dim protocol: 0
    Is Z-Wave Device: 4096
    supports direct-level dimming other than preset dim, extended data, or Z-Wave: 0
    status change - call SetIO/SetIOEx : 0
    value change - call SetIO/SetIOEx: 0
    this device will only allow ON and OFF actions in the event properties: 0
    device will not appear in the device status change trigger list or the device condition list: 0
    Transitioning to HS3Pro .298 - WinXPEmbedded
    Hometroller S3 Pro - WinXPEmbedded - HSP 2.5.0.81 - BLStat - HSPhone - HSTouch Srvr 1.0.0.73 - Touchpad - BLLan - BLOccupied - DSC Plug 2.0.0.14 - BLStat .38
      ALL 4 OF MY THERMOSTATS ARE WAYNE DALTON
      Device Code: Q15
      Full Name: Basement Thermostat 61
      Location 2: Z-Wave
      Type: Z-Wave Thermostat
      Z-Wave Manufacturer ID: 8
      Z-Wave Product ID: 32
      Z-Wave Product Type: 7
      Device Code: Q25
      Full Name: Bonus Room Thermostat 74
      Location 2: Z-Wave
      Device Code: Q19
      Full Name: Great Room Thermostat 65
      Location 2: Z-Wave
      Device Code: Q22
      Full Name: Master Bedroom Thermostat 69
      Location 2: Z-Wave
      Bigmack48
        Bigmack,
        What model is the Wayne Dalton?
        Cheers,
        Bob
          WAYNE DALTON - WDTC-20
          Bigmack48
            Just installed mine today!
            Make and Model: 2GIG-ZSTAT CT30E - Z-Wave Thermostat (2Gig)
            Z-Wave Manufacturer ID: 152
            Z-Wave Product ID: 30
            Z-Wave Product Type: 1
            Bryan
            Software/Hardware: Win10 Pro, HS 3 Pro, HS Touch, Echo, Edgeport/4, Z-Net w/88 Devices, Insteon PLM w/19 Devices, Nest, GC-100-6, W800RF32A, WS-2080 Weather Station (KMADRACU10)
            Plug-in/Scripts: Alexa API, BLBackup, BLGData, BLLED, BLLock, BLRF, BLTVGuide, Blue Iris, BLUPS, Current Cost 3P, DirectTV, FitbitSeer, Insteon, Nest, Pushover 3P, Random, Restart, Tasker, UltraGCIR3, UltraWeatherWU, Z-Wave
              Thermostat: RCS Model TZ43 (manual that came with it says Rev 1)
              Device Code: Q6
              Full Name: MBR MBR Thermostat
              Location 2: MH - Upper
              Z-Wave Manufacturer ID: 16
              Z-Wave Product ID: 2
                4 * TZ16 (RCS)
                Z-Wave Product ID: 1
                HS3 Pro Edition 3.0.0.435 (Windows 10 vmware)
                BLOccupied:,UltraNetCam3:,weatherXML:,RFXCOM:,Current Cost 3P:,UltraGCIR3:
                DMMQTT:,Kodi:,Z-Wave:,BLRadar:,EasyTrigger:,MySensors:,BLBackup:
                  Originally posted by dmurphy View Post
                  4 * TZ16 (RCS)
                  Are those all the same model number of the TZ16. I notcied that they are not all the same values.
                  Cheers,
                  Bob
                    Yep there all tz16, two different mfg versions I believe. They all have the same firmware, but in getting them updated the 'older' versions caused some challenges for RCS to get them flashed with latest firmware.
                    Dan.
                      Here is what tech support at RCS had to say about those units, when they upgraded the firmware.
                      We received your Z-Wave dongles in-house on 7/31/9; checked into tech repair queue on 8/1/09.
                      So far, 2 of the newer units [ 300 series Z-Wave IC ] are reloaded with the latest firmware.
                      Engineering is looking at whether or not the latest firmware can be loaded into the older revision
                      dongles [ 200 series Z-Wave IC and no cost ] <<or>> the board will have to be replaced [ at cost ].
                      They did the firware upgrades at no cost!!! RCS rocks!
                        I have three CT20 thermostats, with the following:
                        Interestingly, that's the same info as the CT30. So they didn't even change the product ID.
                        Chris
                          I just got a new ZWave Thermostat from Ebay and it was sold as a 2Gig CT30. However, although it looks identical to my CT30, it has a different label on it - Vivint. And the instruction manual is clearly labeled as Vivint.
                          I found the thermostat here:
                          http://www.vivint.com/support/techni...at/useroptions
                          It seems to work the same as my 2Gig, but it also has a battery level device which is really cool. The downside is that it doesn't have a polling option.
                          When I run the script command, I get the following for the Vivint (which appears to be a new entry):
                          Z-Wave Product ID: 344
                          Z-Wave Product Type: 7696
                          The entry for my 2GIG matches what everyone else has posted.
                          I still have an issue with the BLStat plugin (http://board.homeseer.com/showthread.php?t=149384), but I wanted to report this info (with the hope that maybe at least one of my thermostats will be recognized by BLStat!)
                          Scott
                            Horstmann ASR-ZW receiver (Boiler Controller)
                            Z-Wave Manufacturer ID: 89
                            Z-Wave Product Type: 3
                            Horstmann HRT4-ZW (Thermostat Controller)
                            see: http://www.horstmann.co.uk/central-heating.php for product details
                              Radio Thermostat Company of America designed the CT100 for 2gigtechnologies
                              Requested Information:
                              Thermostat Make and Model: 2gigtechnologies CT100
                              Z-Wave Manufacturer ID - 152
                              Z-Wave Product ID - 259
                              Z-Wave Product Type - 25601
                              BLStat-Thermostats returns following error: "Error in StatName, Object reference not set to an instance of an object. (1) (Manufacturer: Unknown)"
