Z-Wave Thermostat Manufacturer Information Needed
This is a sticky topic.
    #16
    I have two CT30 stats bought late 2011 from HomeSeer. Reporting them since the numbers on mine appear to be different than the other CT30s reported so far.
    2GIG ZStat CT30 Z-Wave Thermostat
    Z-Wave Manufacturer ID: 152
    Z-Wave Product ID: 348
    Z-Wave Product Type: 7698
    Cheers
    Al
    HS 4.2.8.0: 2134 Devices 1252 Events
    Z-Wave 3.0.10.0: 133 Nodes on one Z-Net
      #17
      Thermostat Make and Model: RCS TZ45
      http://store.homeseer.com/store/RCS-...tat-P1113.aspx
      http://www.rcstechnology.com/pages/p...mo-z-wave.html
      Z-Wave Manufacturer ID: 16
      Z-Wave Product ID: 9
      Z-Wave Product Type: 1
      Thanks You!
        #18
        I believe I have added all in this thread to the latest build.
        If not please let me know
        Cheers,
        Bob
          #19
          Hi Bob,
          When I look at the Thermostats page in the plug-in, it reports them as:
          Hallway Main Floor Thermostat (1)
          (Manufacturer: Unknown)
          Master Bedroom Second Floor Thermostat (2)
          I'm using plug-in version 1.0.31.0. Is there a newer one?
          Al
            #20
            Yes check my site or the updater for the newest build
            Cheers,
            Bob
              #21
              Thanks Bob, updated and it now show my thermostats correctly.
              Al
                #22
                ok Blade, this is what I got, the model is a Honeywell th8320zw1000:
                Device Code: Q11
                Full Name: Z-Wave Interface Z-Wave Thermostat 25
                Location 2:
                Type: Z-Wave Thermostat
                Z-Wave Manufacturer ID: 57
                Z-Wave Product ID: 1
                Z-Wave Product Type: 17
                Can Dim: False
                Interface:
                Buttons:
                Values:
                Graphics:
                Misc: 4112
                Supports Pre-Set Dim: 0
                Supports Extended Dim: 0
                SmartLinc Switch: 0
                No Logging Changes: 0
                Status Only: 16
                Is Thermostat: 0
                Include in PowerFail: 0
                Value names are selectable from the Control screen : 0
                Create voice command(s): 0
                Voice commands must be confirmed for this device: 0
                uses the Compose preset-dim protocol: 0
                Is Z-Wave Device: 4096
                supports direct-level dimming other than preset dim, extended data, or Z-Wave: 0
                status change - call SetIO/SetIOEx : 0
                value change - call SetIO/SetIOEx: 0
                this device will only allow ON and OFF actions in the event properties: 0
                device will not appear in the device status change trigger list or the device condition list: 0
                Hector
                Win.2003 OS, HS3
                MyTrigger,ACRF2,W800,Zwave
                AP800,Honeywell Stat
                  #23
                  Hey Bob
                  Any info regarding the Tstat name?
                  Hector
                  Win.2003 OS, HS3
                    #24
                    Try version 1.0.38 on my web site or in the HS updater
                    Cheers,
                    Bob
                      #25
                      Yes Bob that did work, thk u.
                      Hector
                      Win.2003 OS, HS3
                        #26
                        Trane TZEMT500BB32MA
                        Z-Wave Manufacturer ID: 139
                        Z-Wave Product ID: 21556
                        Z-Wave Product Type: 21586
                          #27
                          I get syntax errors running it... but didnt have the tstat plugin installed.. so I did and it tells me the model is what Rotech has.. so I dont need to put mine up here.. just not sure why the syntax error...
                            #28
                            this did not work.. I ran the command in the control panel.. but nothing happened.. I do not see the file you say it should show
                            Running script(2) &hs.RunEx "Display_ZWave_Thermostat_Device_Info.vb", "Main", "", init error: Syntax error
                            Dec-22 15:13:58
                            Event
                            Running script statement immediately: &hs.RunEx "Display_ZWave_Thermostat_Device_Info.vb", "Main", ""
                              #29
                              Bob,
                              It seems you script to obtain the TStat information is not working. I get the following error.
                              Running script C:\Program Files (x86)\Homeseer HS3\scripts\Display_ZWave_Thermostat_Device_Info.vb :Exception has been thrown by the target of an invocation.Public member 'hc' on type 'DeviceClass' not found.
                              I have a GoControl TBZ48 and it is not being recognized by your plugin.
                              Judd
                                #30
                                What version of HS3 are you running?
                                Maybe they removed the house code property from the device class
                                I will take a look
                                Cheers,
                                Bob
