Error with the plugin
  • Error with the plugin
    FYI
    1/2/2011 3:43:56 PM
    ZWave Thermostats Aborting poll of this thermostat due to and error retrieving the temperature. Node: 41/2/2011 3:43:30 PM BLStat Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: INSERT INTO tblStatData (txtDateTime,txtThermostatNumber,txtMode,txtState,txtSeconds ) VALUES('1/2/2011 3:43:30 PM',2,1,0,63429579810)1/2/2011 3:43:30 PM BLStat Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): DatabasePathAndName: C:\Program Files\HomeSeer HS2\Data\BLStat\BLStat.mdb1/2/2011 3:43:30 PM BLStat Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): An error has occurred during database update statement: Data type mismatch in criteria expression.1/2/2011 3:43:30 PM BLStat Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: INSERT INTO tblStatData (txtDateTime,txtThermostatNumber,txtMode,txtState,txtSeconds ) VALUES('1/2/2011 3:43:30 PM',1,1,0,63429579810)1/2/2011 3:43:30 PM BLStat Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): DatabasePathAndName: C:\Program Files\HomeSeer HS2\Data\BLStat\BLStat.mdb1/2/2011 3:43:30 PM BLStat Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): An error has occurred during database update statement: Data type mismatch in criteria expression.1/2/2011 3:43:24 PM BLStat Info 2 Thermostats have been loaded
    Do you see this all the time?
    Cheers,
    Bob
      Please tell me when this occurred.
      Did it occur when you started the plugin?
      Cheers,
      Bob
        Try build 1.0.2d and see if it fixes it.
        Cheers,
        Bob
          Hi Blade,
          I will try it tonight. I just saw it once at the start of the plugin, I will keep you posted.
          Aldo
            Yeah I had a feeling you saw it at the start of the plugin.
            The newest build should fix it.
            Cheers,
            Bob
