Cool setting
  • Cool setting
    Hi Blade,
    Can I remove the "Cool" devices? My boiler only supports "Heat"
    Aldo
    I will add an option for that on the options page
    Cheers,
    Bob
      Thanks, I know you are asking for input, let me know if you would like me to stop
        This will be in the next build.
        You can specify it per thermostat
        Cheers,
        Bob
          This is included in build 1.0.2e I just posted.
          Cheers,
          Bob
            This is what I get when I click on the option on the thermostat.
            By the way I still get the errors during the startup.
            1/3/2011 8:34:49 PM - BLStat Error - DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: INSERT INTO tblStatData (txtDateTime,txtThermostatNumber,txtMode,txtState,txtSeconds ) VALUES('1/3/2011 8:34:49 PM',2,1,0,63429683689)
            Webpage error details
            User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729)
            Timestamp: Tue, 4 Jan 2011 01:36:54 UTC
            Message: 'document.thermostats.thermostat_to_show_options' is null or not an object
            Line: 78
            Char: 3
            Code: 0
            URI: http://192.168.0.15:8080/blstat?page=blstatthermostats
              Are you using Internet Explorer?
              It works here with IE.
              Regarding the database error...
              OK I need you to do the following:
              1. Shutdown HS
              2. Edit hspi_BLStat.ini in your config folder and change debugLevel=true
              3. Save ini file
              4. Restart HS
              Once HS has been started for a few minutes then go to the BLStat options page and disable debug logging.
              Then zip up the BLStat-Detailed.log file in your HS root folder and attach the zip to this thread.
              Cheers,
              Bob
                Hi Blade,
                I used IE and Chrome both do not work.
                  Please capture it happening in a debug log so I can see it.
                  It works perfectly here so I cannot duplicate it.
                  Attach the zipped log to this thread.
                  Thx
                  Cheers,
                  Bob
                    Hi Blade,
                    The log will provide you the three issuse that I'm experiencing.
                    1) Database error at startup
                    2) Options not working ( I used IE, firefox and Chrome) the click on it does not do anything.
                    3) The action to decrease to 1 decrease should be captured here as well.
                    P.S I had to restart HS 2 times, the first time I got a message about not been able to start one thermostat, so you should see two restarts.
                    Aldo
                      I think they should all be fixed in build 1.0.2f I just posted.
                      Let me know
                      Cheers,
                      Bob
                        Your name should be "speedy gonzales" you are super fast. All three fixes worked great.
                        By the way I noticed that I still have the "cool" device in my list under the status screen, can I remove it?
                        Thank you,
                        Aldo
