Action does not work
  • Action does not work
    Hi Blade,
    Not sure you know it, the action that increase the temperature by 1 degree is not working. It is not doing any action.
    BLStat:BLStat Action: Thermostat - Family Thermostat Family Room; Increase Temp By 1 Degree
    By the way it works using your function via script.
    hs.Plugin("BLStat").IncreaseSetpoint(1)
      Was it in hold mode when you did this?
      I will have a look and see f the code is the same in both places.
      Cheers,
      Bob
        The code is the same in both places.
        You are going to have to enable debug logging on the options page. Then capture the issue happening, then disable debug logging and attach the BLStat-Detailed.log file (ZIPPED) to this thread.
        I have no idea what is happening until I see the debug log.
        Cheers,
        Bob
