I am trying to get the schedule's to work the way I think it's suppose to. The schedule seems to work for me and set the proper setpoints at the right times but only at those stated times. Right now I am able to make manual changes to the thermostats without blstat ever reverting to the schedule that is set.
IE cool setpoint is set to 71 in the schedule.
I change the setpoint manually to 77. And it just stays there. Never reverts.
Under the thermostats page it says the
Thermostat is in RUN Mode and reflects the manually set setpoint of 77 even though the schedule says 71 and the options should revert after a minute if I am understanding everything correctly.
Probably 1 time out of 10 it will say Manual Mode and says the countdown is 1 minute away. 10 minutes pass and its still set at my manual setpoint.
Options I have enabled
-On the thermostats options page these are enabled
-Manual Setpoint Changes is
Enabled
Activate Immediate Timer
Schedule Overrides Manual Changes
Allow manual setpoint changes for 1 minutes before resuming the thermostat schedule
On the main options page I have set
Operating State Control
My other issue is how to get BLSTAT to set the setpoints according to my schedule when the schedule is loaded by an event. I have an event that when I lock my door that it loads a schedule that is heat 62 and cool 82. The schedule gets loaded but doesn't change the values until a time I set in the schedule crosses. And vice versa. So if I my schedule is set to change at 12 pm and 6 pm and I leave at 3 PM. nothing happens until 6pm according to the schedule. Shouldn't the setpoints get set when the schedule is loaded based on the time? In this case, shouldn't it set the setpoint for the 12pm time. Or am I missing something?
I am running version 1.0.30 I also tried 1.0.27. Is there an older version where this works the way I am thinking? From what I have been reading on the forums and it seems everyone has the opposite problem of being unable to get it to stop reverting automatically.
Enabled
