Does anybody knows how the filter reminder works?
Filter Reminder??
Originally posted by jbbtex View PostYou set the number of days between filter changes. It will trigger an event and/or run a script that you create after the set amount of time elapses. The event/script will trigger everyday until you reset the reminder.
Under script command I have entered: &hs.triggerEvent "air filter notification"
Should that work when the counter reaches cero?Hector
Win.2003 OS, HS3
MyTrigger,ACRF2,W800,Zwave
AP800,Honeywell Stat
Originally posted by Rotech View PostIhave made a manual event that emails me when the filter needs changing.
Originally posted by jbbtex View PostNo, it needs to be VB.Net syntax. Just change it to &hs.triggerEvent("air filter notification"). Or you could just select "air filter notification" in the "Event Name" dropdown.Hector
Win.2003 OS, HS3
Originally posted by Rotech View PostI have it selected in the drop down list, but nothing occurs, I will try adding VB.net syntax.
On the bottom of the BLStat-Thermostat page, just above the Reset Filter button it should say when the next filter change is due. It won't trigger the event/script until that date.
Originally posted by jbbtex View PostHere are my settings on the BLStat-Options page. Every thirty days, I get an email to change the filter.
On the bottom of the BLStat-Thermostat page, just above the Reset Filter button it should say when the next filter change is due. It won't trigger the event/script until that date.Hector
Win.2003 OS, HS3
Thk you brady that is exactly what I made a manual event. Does your setup notify you when it's time to change temp. In the normal schedule mode?Hector
Win.2003 OS, HS3
I don't no what's happening with mines, when it's about to change temp it's say that there a manual change, when no ones has touch the stat. And it happens when it's in the schedule mode.Hector
Win.2003 OS, HS3
