Can't find any thermostats
  • #16
    sounds good, i will try removing and re-adding both stats tonight.
    HS Install Date: Feb. 16, 2007
    HS3 Pro, Z-Wave, Insteon, BLStat, HS Touch Server, MyQ
    WeatherXML, BLBackup, BLLAN, BLLock, Restart, CaddX, OpenSprinkler
    • #17
      I just loaded .43 and my stats are working fine.
      Remove them and add them again
      Cheers,
      Bob
      • #18
        removed them, added them again. now the one is not reporting the missing child error as it was previously, but still nothing in blstat. they are both fully functional in hs3, blstat just doesnt pick them up.
        • #19
          That is very odd. I wonder why they would be missing the value
          Run the script in this thread and post the log
          http://forums.homeseer.com/showthread.php?t=160997
          Cheers,
          Bob
          • #20
            Interesting, the script errors out:
            Compiling script HS3_Display_ZWave_Thermostat_Device_Info.vb: Namespace or type 'HomeSeerAPI' has already been imported.
            • #21
              I have updated the script
              Download and try again
              Cheers,
              Bob
              • #22
                Script log file attached:
                • #23
                  It is very odd why the thermostat root devices dont show a subtype api for yours.
                  I will have to add some code to take care of this. I will do tonight once I am home from work. Will have a new build for you to try tonight.
                  Cheers,
                  Bob
                  • #24
                    is this something i should submit in to homeseer as a bug instead?
                    • #25
                      I am not sure it would get very high priority.
                      I will fix it
                      Cheers,
                      Bob
                      • #26
                        Try build 2.0.9 in the HS3 updater and let me know
                        Cheers,
                        Bob
                        • #27
                          I get a 404 file not found error trying to update, I will try in a few hours after dinner, maybe the files arent ready for download yet?
                          • #28
                            Should be there.. I use dropbox... keep trying
                            Cheers,
                            Bob
                            • #29
                              Got it installed, came across as 2.0.10 though. But yes, it is now working...Thank you very much, will test the next few days.
