HS3 ver.44 broke blstat
  • HS3 ver.44 broke blstat
    Tried ver.44, first thing I notice on log blstat did not load the tstat. Optimized my zwave net. Devices show in device page but blstat does not see it. Anybody else have this issue?
    Hector
    Win.2003 OS, HS3
    MyTrigger,ACRF2,W800,Zwave
    AP800,Honeywell Stat
    I have not loaded .44 yet
    I will load it shortly and check it out.
    Cheers,
    Bob
      My thermostat loaded fine with .44
      Cheers,
      Bob
        I polled it thru the plugin and it does not want to load... Restarted HS don't understand??
        Hector
        Win.2003 OS, HS3
          Do the following:
          1. Shutdown HS3
          2. Edit hspi_BLStat.ini file and change debugLevel=true
          3. Save INI file
          4. Restart HS3
          Let HS3 run for 2 minutes after it is completely started and then go to the BLStat options page and turn off debug logging.
          Attach the BLStat-Detailed.log file so I can see it
          Cheers,
          Bob
            Try build 2.0.9 in the HS3 updater and let me know
            Cheers,
            Bob
              Bob,excellent job, that worked.... Idont know if this has to do something with the plug, but aim not getting any reading for these devices..
              PS: its the box with the icon, I drew the circle wrong.
              Hector
              Win.2003 OS, HS3
                Bob, when I went to close HS3, I found this error in the start un log, dont know if its importante:
                11/24/2013 11:20:23 AM ~!~Error~!~Calling HSEvent in plugin BLStat, Instance :Object reference not set to an instance of an objec
                Hector
                Win.2003 OS, HS3
                  Problem with HS3 version .44
                  Track this bug http://homeseer.com/bugzilla/show_bug.cgi?id=1229
                  Dirk
