This is part feature request and part request for some help...
The issue is that the Set Run/Hold action in BLStat events does not allow for input of the hold temperature, so two actions are needed, first set the set point, then set the hold on. The request would be to make the event action similar to the thermostats page where you can also plug in the set point and duration of the hold
I frequently need to set 9 thermostats in a vacation home to hold, and I asked for this enhancement in the HS2 version, but Blade suggested I run this immediate script instead, that worked well in HS2.
&hs.Plugin("BLStat").SetHoldOn(1, 55)
sets tstat 1 in to indefinite hold 55F
&hs.Plugin("BLStat").SetHoldOff(1)
turns off the hold mode.
now, how do I translate this in to the HS3 equivalent statement to run as immediate script? I guess I should add that if I knew how to write scripts I probably would not have to ask...
Johan
Johan
