The plugin uses the subtype to look up the individual devices for mode, temp, setpoint, etc
These are set by the zwave plugin when the stat is added
BLStat not finding my thermostats?
Ahh - the type could be my issue. Besides the root being labeled "Z-Wave Thermostat Root Device" do any of the child devices that need a specific name?
That is odd.
If the device was not of the right type then BLStat would not have found them. Maybe the rescan fixed the device
The devices were already under the control of HS3 but BLStat wouldn't find them. Only when I rescanned them (which didn't make any changes to the device status page), did BLStat find them.
BLStat needs the stats to be in HS3 as devices before it can find them.
After doing a Z-Wave rescan of all my thermostats, BLStat then found them. Possibly a bug in BLStat?
I'm just transitioning to HS3 (from HS2) and trying out BLStat. However it's reporting that I have no thermostat. HS3 I believe recognizes all 4 thermostats as I have the ability to see and control all of them. So I'm not sure what I'm doing wrong.
Can anyone assist?
Here's an example of a rescan for one of my thermostats thinking that maybe BLStat doesn't support Trane?
Z-Wave manufacturer information for node 3, ID: 139=8BH (Trane Corp), Type: 21586=5452H, ID: 21553=5431H
Node: 3 Supports Class(es): THERMOSTAT_MODE_V3, THERMOSTAT_OPERATING_STATE, THERMOSTAT_SETPOINT, THERMOSTAT_FAN_MODE_V3, THERMOSTAT_FAN_STATE, CONFIGURATION_V2, SENSOR_MULTILEVEL, VERSION_V2, CLOCK, MANUFACTURER_SPECIFIC_V2, LOCK, ASSOCIATION_V2
Happy to provide any other data. Thanks in advance..Tags: None
