When will the run time chart be available?
    I have installed a new HVAC about a mouth ago, and I would like to know the actual rum time. Currently this feature is broken, when will it be available for use?
    Hector
    Win.2003 OS, HS3
    MyTrigger,ACRF2,W800,Zwave
    AP800,Honeywell Stat
    I did not write that part. It was contributed by Steve Anderson but I will fix it
    Add a help desk ticket for it so it reminds me
    Cheers,
    Bob
      Thk u Bob.
      Hector
      Win.2003 OS, HS3
        The HS2 chart can only calculate right if you have the thermostat in heat or cool mode, but not if it is on auto. This is quite annoying, since we keep it on auto during a few months every year. This should be correctable, because even though the thermostat is in auto, HS knows if it is cooling or heating when the thermostat is running. Could this also be sorted out, if not in HS2, then at least in HS3 (assuming the same bug exists)?
          I don't understand, how did you get to that conclusion?
          Hector
          Win.2003 OS, HS3
            Mention that in the ticket and I will check into that as well
            Cheers,
            Bob
              Info smmitted to ticket.
              Hector
              Win.2003 OS, HS3
                OK I will get to it. I am not ignoring anyone
                Cheers,
                Bob
                  Thanks Rotech!
                    Hi Bob, any time frame on this?
                    Hector
                    Win.2003 OS, HS3
                      Bump
                      Hector
                      Win.2003 OS, HS3
                        Another bump. Just realized that it did not work today, just as I was going to demonstrate it to my wife how easy it was to see the activity in a graphical format...
                        Server Error in '/' Application.
                                       Unrecognized database format 'C:\Program Files (x86)\HomeSeer HS3\Data\BLStat\BLStat.s3db'.
                                                     Description: An unhandled exception occurred during  the execution of the current web request. Please review the stack trace  for more information about the error and where it originated in the  code.
                                      Exception Details: System.Data.OleDb.OleDbException: Unrecognized database format 'C:\Program Files (x86)\HomeSeer HS3\Data\BLStat\BLStat.s3db'.
                                     Source Error:
        Line 36: 	If NOT (Page.IsPostBack) Then Line 37: 		Dim i_days as Integer = 7 Line 38: 		DropDownList1.DataBind() Line 39: 		DropDownList1.SelectedIndex = 0 Line 40: 		Dim almostDay as System.TimeSpan = New System.TimeSpan(0,23,59,59)
                                      Source File:  C:\Program Files (x86)\HomeSeer HS3\html\BLStat\BLStat_hrs_per_day.aspx    Line:  38
                                     Stack Trace:
        [OleDbException (0x80004005): Unrecognized database format 'C:\Program Files (x86)\HomeSeer HS3\Data\BLStat\BLStat.s3db'.]    System.Data.OleDb.OleDbConnectionInternal..ctor(OleDbConnectionString constr, OleDbConnection connection) +325    System.Data.OleDb.OleDbConnectionFactory.CreateConnection(DbConnectionOptions options, DbConnectionPoolKey poolKey, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningObject) +87    System.Data.ProviderBase.DbConnectionFactory.CreateConnection(DbConnectionOptions options, DbConnectionPoolKey poolKey, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningConnection, DbConnectionOptions userOptions) +22    System.Data.ProviderBase.DbConnectionFactory.CreateNonPooledConnection(DbConnection owningConnection, DbConnectionPoolGroup poolGroup, DbConnectionOptions userOptions) +38    System.Data.ProviderBase.DbConnectionFactory.TryGetConnection(DbConnection owningConnection, TaskCompletionSource`1 retry, DbConnectionOptions userOptions, DbConnectionInternal oldConnection, DbConnectionInternal& connection) +727    System.Data.ProviderBase.DbConnectionInternal.TryOpenConnectionInternal(DbConnection outerConnection, DbConnectionFactory connectionFactory, TaskCompletionSource`1 retry, DbConnectionOptions userOptions) +143    System.Data.ProviderBase.DbConnectionClosed.TryOpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory, TaskCompletionSource`1 retry, DbConnectionOptions userOptions) +17    System.Data.ProviderBase.DbConnectionInternal.OpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory) +17    System.Data.OleDb.OleDbConnection.Open() +23    System.Data.Common.DbDataAdapter.FillInternal(DataSet dataset, DataTable[] datatables, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior) +119    System.Data.Common.DbDataAdapter.Fill(DataSet dataSet, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior) +135    System.Data.Common.DbDataAdapter.Fill(DataSet dataSet, String srcTable) +85    System.Web.UI.WebControls.SqlDataSourceView.ExecuteSelect(DataSourceSelectArguments arguments) +1423    System.Web.UI.WebControls.AccessDataSourceView.ExecuteSelect(DataSourceSelectArguments arguments) +57    System.Web.UI.WebControls.ListControl.OnDataBinding(EventArgs e) +101    System.Web.UI.WebControls.ListControl.PerformSelect() +21    System.Web.UI.WebControls.BaseDataBoundControl.DataBind() +71    ASP.blstat_blstat_hrs_per_day_aspx.Page_Load(Object sender, EventArgs e) in C:\Program Files (x86)\HomeSeer HS3\html\BLStat\BLStat_hrs_per_day.aspx:38    System.Web.UI.Control.OnLoad(EventArgs e) +61    System.Web.UI.Control.LoadRecursive() +98    System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2640
                                                   Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.34209
                          I have it almost working.
                          Cheers,
                          Bob
                            Oh, Bob. Not a problem at all. Love the plugin. Couldn't live without it.
                              I knew I was annoying lots of people with my walking away from HS3 (err, never really walked TO it in the first place), but I hadn't even thought about this chart.
                              No matter, as Bob will make it better than it ever was from me anyway.
                              Sorry, everyone!
                              Steve
