Entering schedules in HS3 BLstat
  • Entering schedules in HS3 BLstat
    Hi,
    I am in the process of converting from HS2 to HS3 and I was entering my times and temps. in the schedule of HS3 BLstat when the following error occurred:
    I entered at 8:15am Heat 60 Cool 78
    10:15am Heat 60 Cool 78
    4:15pm Heat 60 Cool 78
    11:15pm Heat 60 Cool 78
    I then copy all of these for every day of the week.
    I named the file Upstairs Vacation 8_22_2014.
    When I go to add this I get an error stating that the time for Sunday Sleep time is not correct ie 9:00am.
    I tried to enter each time and temp. but still get the same error.
    Any Ideas?
    Also can HS2 schedules be imported or used in HS3?
    Thank You in advance,
    Ronnie
    You should be able to copy the over the hspi_BLStat.ini file from HS2 and use it in HS3
    Cheers,
    Bob
      Originally posted by Ronnie View Post
      Hi,
      Any Ideas?
      Ronnie
      The format on the schedule screen is very particular, you have to make sure you enter your time as 9:00 am, note the space before am.
      HS Install Date: Feb. 16, 2007
      HS3 Pro, Z-Wave, Insteon, BLStat, HS Touch Server, MyQ
      WeatherXML, BLBackup, BLLAN, BLLock, Restart, CaddX, OpenSprinkler
        Thank you,
        That was the problem. I did not have a space between the time and am or pm.
        Thanks again,
        Ronnie
