HS3 - Error on one of the termostat
  • HS3 - Error on one of the termostat
    Hi Blade,
    I'm getting this error on one of my thermostat when I start your plugin, do you know what it may be? It is a CT30 ZWave. I have other 3 same model with no issues. I have also installed your plugin on HS2 without issues.
    Dec-25 7:54:22 PM Device Control Device: Z-Wave Node 3 Z-Wave Interface Thermostat Basement Main Fan Mode to Auto (0) by/from: CAPI Control Handler Dec-25 7:54:22 PM Z-Wave Device: Z-Wave Node 3 Z-Wave Interface Thermostat Basement Main Fan Mode Set to 0 Dec-25 7:54:21 PM Device Control Device: Z-Wave Node 3 Z-Wave Interface Thermostat Basement Main Fan Mode to On (1) by/from: CAPI Control Handler
    I am not sure that is actually coming from the plugin
    Cheers,
    Bob
      Hi Blade, it only happens when I turn the plugin on. May be of any help if I can give you some kind of debugs?
      Thanks for looking into this,
      Aldo
        Log a ticket on my web site
        Turn on debug logging in the plugin and capture the issue then turn off debug logging and attach the BLStat-Detailed.log file zipped to the ticket
        Cheers,
        Bob
          Thanks Bob, all set. You may find the log on your web site.
          Aldo
            Hi Bob,
            I identified the issue you may want to check your plugin. If I Flag the fan on without any other values in it, it will trigger the thermostat fan to go on and auto every second or less. Please see attached picture.
