BLStat 2.0.52
This is a sticky topic.
  • BLStat 2.0.52
    I have attempted to get the Run Times chart report working again in this build.
    You will need to install the SQLite ODBC driver on your HS3 machine in order for this to work
    Here is the link for the driver:
    http://www.ch-werner.de/sqliteodbc/
    Once you are on the web site, I downloaded the sqliteodbc.exe link and installed it on my HS3 machine and it seems to work fine.
    After you have installed the sqliteodbc driver then do the following:
    1. Update BLStat to the latest in the HS3 updater
    2. You need to make sure that the System.Data.SQLite.dll file in your [HS3 root]\Bin\BLStat is the same file size as the one in [HS3 root]\html\bin (the file size should be 246Kb)
    3. If they are not the same copy the one from [HS3 root]\Bin\BLStat to [HS3 root]\html\bin and overwrite it (you may have to shutdown HS3 in order to do it)
    Cheers,
    Bob
    downloaded rev.2.0.50.0 and installed driver, first attempt got this error
    Hector
    Win.2003 OS, HS3
    MyTrigger,ACRF2,W800,Zwave
    AP800,Honeywell Stat
      Tell me what DLL files exist in your HS3 root folder
      Cheers,
      Bob
        Also show me what files are in [HS3 root folder]\BIN\BLStat
        Cheers,
        Bob
          Bob
          There lots of them, any particular you looking for?
          Hector
          Win.2003 OS, HS3
            What are the ones starting with S?
            Cheers,
            Bob
              Netchartdir.dll
              SQLite3.dll
              SQLite.interop.dll
              System.data.sqlite.dll
              Hector
              Win.2003 OS, HS3
                Also show me what programs are installed on your computer starting with SQLite. You can see these in the uninstall program area in control panel
                Cheers,
                Bob
                  Scheduler.dll
                  Scheduler.dll.config
                  Hector
                  Win.2003 OS, HS3
                    Here you go.
                    Hector
                    Win.2003 OS, HS3
                      Originally posted by Rotech View Post
                      Netchartdir.dll
                      SQLite3.dll
                      SQLite.interop.dll
                      Do these 4 files exist in [HS3 root]\html\bin
                      Cheers,
                      Bob
                        only the netchartdir.dll. the rest do not exist.
                        Hector
                        Win.2003 OS, HS3
                          Can you download 2.0.51 from the updater and let me know
                          Cheers,
                          Bob
                            I am getting a error on the updater:
                            The remote server returned an error:404 not found
                            Hector
                            Win.2003 OS, HS3
                              downloaded.51 and got this
                              Hector
                              Win.2003 OS, HS3
