Error/warning messages in log
  • sparkman
    Originally posted by Blade View Post
    If you ask around on the forums I think you will find out that my plugins are respected on here.
    Yes and probably the best supported for both the paid ones and the free ones. It's quite common for Bob to release fixes the same day an issue is identified. I have a number of the Blade plugins (more than my signature shows as I the character limit in my signature block) and am extremely satisfied with all of them.
    Cheers
    Al
  • Blade
    No problem... BLStat for linux is fairly new but I am sure we can work thru the issues
    Let me know and I will get your trial reset
  • mikedr
    I think you are jumping to conclusions a little too fast but that is your decision.
    Let me know if you want any further help.
    Sorry, that came across as a bit harsh. I apologize; bad day at work! I'm going into a busy work mode for the next few weeks, so I won't have time to mess around with this. Is there any way to reset the trial period when I have time again? Right now it's uninstalled on my system.
  • Blade
  • mikedr
    Yes they do. And I still have the error messages. I contact HomeSeer support, and they say that there's something wrong with the plugin code as to why it's not reinstalling properly.
    I appreciate your help on this, but, truth to told, the inability to get this plugin working has left a bad taste in my mouth for your plugins -- I was thinking of getting about a half-dozen based on the functionality, but if I can't even get the first one working, well . . . . .
    Going to shelve this project for now, and will stick with using events in HS3 to control my thermostats. Sorry.
  • Blade
    These are the files that should exist in [hs root]/bin/BLStat
    SQLite.Interop.dll
    sqlite3.dll
    System.Data.SQLite.dll
    Do they all exist?
  • mikedr
    SqLite.Interop.dll should be installed in [Hs root]/bin/BLStat along with some other files
    Should I delete them and have them reinstall?
  • Blade
  • mikedr
    OK, I rooted in and deleted everything that looked relevant. Still getting the errors. Take a look at these two log screens.
    Is SqLite.Interop.dll something that comes with HS3, or is that something your plug-in installs? If it's not required by HS3 other than for your plug-in, I can delete it and do another re-install. If it is required, then there is some incompatibility between the plug-in and HS3's core files.
  • mikedr
    You will have to connect as an admin user and remove the files and make sure BLStat is not enabled. I have never used a Hometroller before so you may have to ask others how to do that
    Can you tell me what files to remove?
    Also, Hometroller is no different than any other Linux install, so if you can tell me how to connect as an admin, I should be able to do that.
  • Blade
  • mikedr
    Is this Linux or Windows
    Linux -- HomeTroller SEL-Pro.
  • Blade
  • mikedr
    I sftp'ed into the box, and there are BLStat files all over. Unfortunately, I can't delete them for whatever reason. I receive permission denied.
    any ideas?
  • mikedr
    Well, more woes. I disabled it, uninstalled it. Then tried to redownload/reinstall. Failed. Rebooted. Redownloaded/reinstalled. Failed.
    See attached. Ideas?
