Temperatures not in schedule being sent to Thermostat
  • Temperatures not in schedule being sent to Thermostat
    I've seen this twice in the last several days. I'm hoping this can be resolved as I like the plugin....but this makes in unusable I have 20 days left in evaluation.
    The symptoms that occur occasionally the cool temperature (90'F) is sent to the heat temperature. So the schedule is set for an away mode - don't cool unless above 90's and don't heat until below 50'F....Heating the house to 90'F while I'm away is less than desirable.
    But there is other strangeness going on as well - see images below.
    HS3 Pro Edition 3.0.0.435 (Windows 10 vmware)
    BLOccupied:,UltraNetCam3:,weatherXML:,RFXCOM:,Current Cost 3P:,UltraGCIR3:
    DMMQTT:,Kodi:,Z-Wave:,BLRadar:,EasyTrigger:,MySensors:,BLBackup:
    And again cool temp being set as high temp!
    So exactly the same has occurred blstat seems to get very confused and I come home to a 90'f house....I live in new england, this time of year that takes some doing....If this can't be fixed, I'll have to port my hs2 script to hs3, was trying to avoid the effort, too much already on my plate with transition....
      3rd strike and its out - blstat removed.
      woke up in middle of the night......heating struggling to get house to 90'f..........Some real bugs in this plugin.
        happened again - debug log this time.......
          I'm having a similar problem. One thermostat' settings seem to be bleeding onto another thermostat... and sometimes its just made up numbers.
          Any solution?
