Does this plugin work for StellaZ and Secure321 ?
  • #16
    Disable BLStat, then restart hs3
    Then update plugin, then enable it
    Cheers,
    Bob
    • #17
      The install worked, and the information in the plugin list of the SRT321 looks better now, I even have a HeatSp, which I dont even have on my StellaZs. So looking better. I loaded a test schedule, lets see if it'll change setpoints but I am optimistic.
      • #18
        Ok I had the first schedules setpoint change on the Secure SRT321 (shows as Horstman in the plugin), it set the thermostat to 11 degrees as it should have. But displaying in the device list setpoint is 50 degrees, as well as the plugin
        • #19
          It looks like it is something to do with Fahrenheit vs Celsius
          Cheers,
          Bob
          • #20
            The schedule has changed the setpoint again, from 11 Celcius to 12 Celcius. Its ok on the Thermostat, but the interface (both) still show 50. 50 Fahrenheit is 10 Celcius, so its not that. It was showing 50 as well when the thermostat was set to 14 Celcius.
            • #21
              Is there going to be a fix for the Secure321 showing 50 instead of the right setpoint ? I guess if it is showing 50 in the device list it will also use that in events if I try to trigger events depending on setpoint.
              • #22
                I have added another 2 StellaZs to my setup, even though they look as if the plugin is recognising them, and temperature updates seem ok, the setpoint displayed is 50... Given the time reference on the device, it looks as if it got the command to change setpoint, its probably just displaying it wrong. But as its summer I am not sure, no heating on at the moment. I have tried enabling and disabling the plugin, and I am on 2.0.69.0
                I have just disabled the plugin, shut down HS3, and restarted. My Securet321 is now finally showing the right setpoint. Great. But the StellaZ's (only the 2 newly added ones) still show 50 as setpoint.
                The Secure321 did display the right setpoint until the next setpoint change. Its displaying 50 again now.
                • #23
                  @Blade
                  Are you still looking into this ? I would appreciate if you can give me some response. If this plugin doesnt work, can I get a refund ?
                  • #24
                    Yes I am looking into it.
                    I do not have all day to dedicate to plugins and will look into it as soon as I can.
                    If you want a refund let me know and I will email HST and tell them to refund you
                    Cheers,
                    Bob
                    • #25
                      Apologies for being impatient. I have no problem waiting, I still have other projects which I can look at in the meantime. As long as I know that you will look at it when you have time, that's good enough for me. I like the plugin and can see a lot of benefits, it looks like a small thing but who knows.
                      • #26
                        I will try to capture a log, I wont be able to today or tomorrow as I am away. Not sure there will be anything to capture though anyway, at least on the Secure321 (Horstman) the setpoint being accepted is correct, its just what's displayed in the device list and the plugin page with the thermostats is wrong, so that's why I am not sure anything will show on the log. But I'll try on Wednesday anyway.
                        • #27
                          So the actual device is wrong in HS3?
                          That device is controlled by the ZWave plugin and BLStat only gets the value from the device.
                          I wonder if it is celsius vs fahrenheit thing in HS3
                          Cheers,
                          Bob
                          • #28
                            I doubt its Fahrenheit to Celsius. The setpoint displayed in HS3 stays at 50 no matter what the setpoint it is actually set to. Unless I reinstall the plugin. Then it shows the correct setpoint in HS3, until its changed. Then its back to displaying 50.
                            • #29
                              OK capture a log when you have time
                              Cheers,
                              Bob
                              • #30
                                In the meantime I have found this. I have sent a change of setpoint to 2 StellaZs via a schedule. The Guest Bed one works fine. The Lounge one is a new one which has a problem with displaying the 50 setpoint.
                                This is a capture of the log from when the command is being sent:
                                Jun-20 16:35:09
                                Device Control
                                Device: Ground floor Kitchen Battery Kitchen Tablet to On (100) by/from: CAPI Control Handler
                                Jun-20 16:35:00
                                Z-Wave
                                New Interface: Thermostat Setpoint Heating 1 value 23 has been added to the Wake-Up queue for Ground floor Heating Setpoint Lounge
                                Jun-20 16:35:00
                                Device Control
                                Device: Ground floor Heating Setpoint Lounge to 23 (23) by/from: CAPI Control Handler
                                Jun-20 16:35:00
                                weatherXML
                                Check timer items
                                Jun-20 16:35:00
                                Z-Wave
                                New Interface: Thermostat Setpoint Heating 1 value 23 has been added to the Wake-Up queue for First Floor Heating Setpoint Guest Bed
                                Jun-20 16:35:00
                                Device Control
                                Device: First Floor Heating Setpoint Guest Bed to 23 (23) by/from: CAPI Control Handler
                                and this is a capture of the activity log from the plugin:
                                6/20/2016 16:55:58 Action Heating Thermostat Lounge (6) Heat Setpoint set to 50 6/20/2016 16:55:58 Action Heating Thermostat Kitchen (5) Heat Setpoint set to 50 6/20/2016 16:55:58 Action Heating Thermostat (4) Heat Setpoint set to 50 6/20/2016 16:55:58 Action Heating Thermostat Lounge (6) Heat Setpoint set to 50 6/20/2016 16:55:57 Action Heating Thermostat Lounge (6) Heat Setpoint set to 23 6/20/2016 16:55:57 Action Heating Thermostat Kitchen (5) Heat Setpoint set to 50 6/20/2016 16:55:57 Action Heating Thermostat (4) Heat Setpoint set to 50 6/20/2016 16:55:57 Action Heating Thermostat Kitchen (5) Heat Setpoint set to 18 6/20/2016 16:55:57 Action Heating Thermostat Lounge (6) Heat Setpoint set to 23 6/20/2016 16:55:57 Action Heating Thermostat Kitchen (5) Heat Setpoint set to 18 6/20/2016 16:55:57 Action Heating Thermostat (4) Heat Setpoint set to 12 6/20/2016 16:55:57 Action Heating Thermostat (4) Heat Setpoint set to 12 6/20/2016 16:55:57 Action Heating Thermostat Guest Bed (2) Heat Setpoint set to 23 6/20/2016 16:55:57 Action Heating Thermostat Study (1) Heat Setpoint set to 18 6/20/2016 16:55:56 Information Heating Thermostat Lounge (6) Schedule: test guest bed has been loaded 6/20/2016 16:55:56 Information Heating Thermostat Kitchen (5) Schedule: test study has been loaded 6/20/2016 16:55:56 Information Heating Thermostat (4) Schedule: Heating off has been loaded 6/20/2016 16:55:56 Information Heating Thermostat Guest Bed (2) Schedule: test guest bed has been loaded 6/20/2016 16:55:56 Information Heating Thermostat Study (1) Schedule: test study has been loaded 6/20/2016 16:55:56 Information Thermostat schedules have been loaded 6/20/2016 16:55:56 Information Bedroom Aircon (7) Manufacturer: Unknown; Model: Unknown 6/20/2016 16:55:56 Information Heating Thermostat Lounge (6) Manufacturer: StellaZ; Model: THIS 6/20/2016 16:55:56 Information Heating Thermostat Kitchen (5) Manufacturer: StellaZ; Model: THIS 6/20/2016 16:55:56 Information Heating Thermostat (4) Manufacturer: Horstmann; Model: HRT4-ZW 6/20/2016 16:55:56 Information Heating Heating control (3) Manufacturer: Unknown; Model: Unknown 6/20/2016 16:55:56 Information Heating Thermostat Guest Bed (2) Manufacturer: StellaZ; Model: THIS 6/20/2016 16:55:56 Information Heating Thermostat Study (1) Manufacturer: StellaZ; Model: THIS 6/20/2016 16:55:56 Information 7 Thermostats have been loaded 6/20/2016 16:35:00 Action Heating Thermostat Lounge (6) Heat Setpoint set to 50 6/20/2016 16:35:00 Action Heating Thermostat Lounge (6) Heat Setpoint set to 50 6/20/2016 16:35:00 Action Heating Thermostat Lounge (6) Heat Setpoint set to 23 6/20/2016 16:35:00 Action Heating Thermostat Lounge (6) Heat Setpoint set to 23 6/20/2016 16:35:00 Action Heating Thermostat Guest Bed (2) Heat Setpoint set to 23 6/20/2016 16:35:00 Action Heating Thermostat Guest Bed (2) Heat Setpoint set to 23
