error on reports
  • error on reports
    Server Error in '/' Application.
    Unable to find an entry point named 'sqlite3_close_v2' in DLL 'sqlite3'.
    Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
    Exception Details: System.EntryPointNotFoundException: Unable to find an entry point named 'sqlite3_close_v2' in DLL 'sqlite3'.
    Source Error:
    Line 37: If NOT (Page.IsPostBack) Then
    Line 38: Dim i_days as Integer = 7
    Line 39: DropDownList1.DataBind()
    Line 40: DropDownList1.SelectedIndex = 0
    Line 41: Dim almostDay as System.TimeSpan = New System.TimeSpan(0,23,59,59)
    Source File: C:\Program Files (x86)\HomeSeer HS3\html\BLStat\BLStat_hrs_per_day.aspx Line: 39
    Stack Trace:
    [EntryPointNotFoundException: Unable to find an entry point named 'sqlite3_close_v2' in DLL 'sqlite3'.]
    System.Data.SQLite.UnsafeNativeMethods.sqlite3_close_v2(IntP tr db) +0
    System.Data.SQLite.SQLiteBase.CloseConnectionV2(SQLiteConnec tionHandle hdl, IntPtr db) +125
    System.Data.SQLite.SQLiteConnectionHandle.ReleaseHandle() +75
    System.Runtime.InteropServices.CriticalHandle.Cleanup() +55
    System.Runtime.InteropServices.CriticalHandle.Dispose(Boolea n disposing) +9
    System.Runtime.InteropServices.CriticalHandle.Dispose() +17
    System.Data.SQLite.SQLite3.Close(Boolean canThrow) +84
    System.Data.SQLite.SQLiteConnection.Close() +255
    System.Data.Common.DbDataAdapter.FillInternal(DataSet dataset, DataTable[] datatables, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior) +337
    System.Data.Common.DbDataAdapter.Fill(DataSet dataSet, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior) +134
    System.Data.Common.DbDataAdapter.Fill(DataSet dataSet, String srcTable) +84
    System.Web.UI.WebControls.SqlDataSourceView.ExecuteSelect(Da taSourceSelectArguments arguments) +1458
    System.Web.UI.WebControls.ListControl.OnDataBinding(EventArg s e) +271
    System.Web.UI.WebControls.ListControl.PerformSelect() +21
    System.Web.UI.WebControls.BaseDataBoundControl.DataBind() +71
    ASP.blstat_blstat_hrs_per_day_aspx.Page_Load(Object sender, EventArgs e) in C:\Program Files (x86)\HomeSeer HS3\html\BLStat\BLStat_hrs_per_day.aspx:39
    System.Web.UI.Control.OnLoad(EventArgs e) +61
    System.Web.UI.Control.LoadRecursive() +98
    System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2732
    Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.6.1073.0
    please advise. Thank you
    Do you have the SQLite dll in your [hs3 root]\bin\BLStat folder
    Cheers,
    Bob
      If this is something I have to do manually. No.
      where do I get this file if I need to manually?
        this is what I have
          Do you have any of those files in your HS3 root folder?
          Cheers,
          Bob
            here is what I have in my root folder
              Hmmm... I do not see the files in the root.
              What version of BLStat are you running?
              It is like the wrong version on SQLite dll is there
              Cheers,
              Bob
                here is a capture
                  Show me what is in [hs3 root]\html\bin
                  Cheers,
                  Bob
                    Here you go
                      Can you confirm that the SQLite files in html\bin are the same as the ones in bin/BLStat
                      Cheers,
                      Bob
                        here you go
                          Hmmm ok - this is odd
                          I wonder if anyone else is seeing the same thing
                          Cheers,
                          Bob
                            The reports have never worked for me. As I am finishing the hardware build for my systems. I am now starting to work on the detailed software side of things.
                              I will take a look as soon as I can
                              Has been very busy recently as we are in the process of a new house build.
                              Cheers,
                              Bob
