can't override schedule with manual increments
  • can't override schedule with manual increments
    After setting up a schedule, how does one override the current schedule setpoints with +1/-1 increments. Every time I try to change the temp manually via HSTouch, the screen shows the increment, but a second later, it goes back to the setpoint specified in BLStat's schedule.
    In the thermostat options have you enabled manual changes?
    Cheers,
    Bob
      Thanks for the fast reply. I totally glossed over that option. Works great now - amazed at how much functionality you put into this!
        Blade, I don't see this option in my Blstat option page. Is this option for HS2?
        Hector
        Win.2003 OS, HS3
        MyTrigger,ACRF2,W800,Zwave
        AP800,Honeywell Stat
          It is under options on each thermostat.
          Randy Prade
          Aurora, CO
          Prades.net
            Randy to the rescue!!! Thank you guy!!. I didn't notice that was there..
            Hector
            Win.2003 OS, HS3
              Internal versus BLSTAT Schedule
              Blade,
              I want to try to run the Filtrete RTC30 t-stat using the internal 7-day program schedule rather than the schedule provided by BLSTAT.
              1. Can I disable BLSTAT schedule by loading a blank schedule? The schedule would say NONE?
              2. If the internal 7-day program is enabled (can't be disabled) does this conflict with the operation under BLSTAT?
              3. Will the plugin report the setpoint for the internal schedule if no schedule is loaded in BLSTAT setup?
              4. Are there option for the t-stat that must be set to have the internal sched override the BLSTAT sched?
              -Cliff
