Can't Load Interface
    I have tried to install the BLUPS Plugin and it keeps stalling "WARNING: Failed getting InterfaceStatus from BLUPS - the interface was not found in the list of active interfaces, the list may need to be refreshed." How does a person get around this? I have tried turning the plugin off and back on several times and it keeps throwing the same error. Other blade plugins work.
    Do you have Powerchute installed on the computer? If so, it must be uninstalled for the plugin to work. More detail in other threads on this board.
      I have the same problem, don't have any Powerchute.
      In the log I have:
      Initializing plug-in(1): BLUPS Instance::No UPS battery exists on this system so this plugin will not run!
      EDIT: found https://forums.homeseer.com/forum/ul...9-blups-faling
